Old 06-25-2015, 02:34 PM   #1
1973 23' Safari
1970 27' Overlander
Boerne , Texas
window replacement
I have a missing front window for a 1972 31 foot sovereign. I have the frame for the window. Can I take the frame into an autoglass shop and ask them to make a window and piece the frame back together? Or is just buying an entire new window/frame the better option.
Greg1410 is offline   Reply With Quote
Old 06-25-2015, 03:22 PM   #2
1997 25' Safari
1973 25' Tradewind
Greenville , South Carolina
Cheaper to go to glass shop and get tempered glass with pencil edge
montanablue is offline   Reply With Quote
Old 06-25-2015, 03:32 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Welcome to the forums!
Yes, the front window can be reglassed, relatively easily. Surely much cheaper than buying a whole new window, frame and all.
Old 07-23-2015, 07:58 AM   #4
Toccoa , Georgia
I am looking for a wing window for my 1973 Argosy.Its the road side one.
Angela Lowe is offline   Reply With Quote
Old 07-23-2015, 08:03 AM   #5
Belegedhel's Avatar
Houston , Texas
These can be bought new from outofdoorsmart.com or Inlandrv.com. You might also find them used from silvertrailersupply.com. You can also look on the classified ads. When you see how much a new unit costs, you might want to be sitting down.
good luck!
Old 07-23-2015, 08:28 AM   #6
Argosy trailers used "wrap windows".
Wing windows are about 14 inches wide. Wrap windows are about 40 inches wide.
You will also need a tube of Vulkem sealer and 100 "Olympic rivets", unless your going to use "buck rivets".
Window Replacement New Window Gaskets pawnguy Windows & Screens 12 09-05-2017 10:17 AM
'58 Hehr Window - Is this the correct window operator replacement? mello mike Windows & Screens 22 10-08-2012 08:49 AM
Curbside Wing window and window by door L&R Rock Guards, Segment & Window Protectors 5 07-07-2009 10:45 PM
Window Latch Assembly (window locks) Sue&Von Windows & Screens 17 02-10-2009 06:32 PM
Replacing Nylon Window Guides - not holding window up Tom Bray Windows & Screens 5 06-16-2008 06:52 AM
