Old 01-29-2016, 01:05 PM   #1
FreedomRings's Avatar
1984 31' Excella
Naples , Florida
Window leaks
Happy, no, exhilarated new Airstream owner, pretty much in mint condition. Have a couple windows with leaks. Someone told me to tow it to a RV service place. But what it looks like to me is the window strips are either dry rot or gone. Wouldn't it be worth replacing the strips and seeing if that takes care of the leaks
FreedomRings is offline   Reply With Quote
Old 01-29-2016, 01:28 PM   #2
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Yes, there is lots of places you can buy new window gaskets. The old ones can be stripped off, and new ones glued on. Many RV dealers carry the gaskets in stock. Post a pic of you new AS and the gaskets and more instruction can be provided.
Also, look up the Vintage Air Stream Podcast (The VAP). Lots of great info on their pods.
Silverflames is offline   Reply With Quote
Old 01-30-2016, 09:46 AM   #3
1984 31' Excella
Naples , Florida
Thank you Silverflames. That would've been the next ? Where to purchase gaskets. Thank you for the VAP info
Old 01-31-2016, 07:55 AM   #4
1969 29' Ambassador
Here is a on line supplier. They are very helpful.
http://www.vintagetrailersupply.com/category-s/26.htm
Old 02-02-2016, 11:13 AM   #5
1984 31' Excella
Naples , Florida
Winodow Leakks
Don't know if theses are good enough pics or not
ID:	256674   Click image for larger version
ID:	256676   Click image for larger version
Old 02-02-2016, 11:50 AM   #6
Window gaskets, depending on their exposure to the sun, can last as little 8 to 10 years, or to even 20 plus years.
The original double flared gasket was OK, back then, but there is a better gasket available that is far superior.
It's a hollow "D" shaped gasket. It seals far superior.
Removing the original gasket and properly installing the D gasket, is very easy. Your supplier would answer that question.
Also check the entrance door gaskets, access compartment gaskets and especially the sewer vent pipe cover gaskets, as they only last 2 to 3 years.
Waterproofing an Airstream is not difficult, but proper materials must be used along with proper installation. Again, your supplier can tell you "how".
Old 02-03-2016, 09:39 AM   #7
1984 31' Excella
Naples , Florida
Yes, my door gasket is totaling missing. Thank you for your advice Andy. That's the next investment is replacing all gaskets, they're all shot.
Old 03-26-2017, 03:52 PM   #8
2004 31' Classic
Jeanerette , Louisiana
Wrap windows
We have a 2005 airstream classic. We,too, have a leak around the wraparound window. Went all the way from Louisiana to factory for them to fix it. Still leaking.
Any suggestions. Going back to the factory is out of the questions.
dmsmith1939 is offline   Reply With Quote
Leaks, leaks, and more leaks da_lizard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-11-2016 11:36 AM
LEAKS LEAKS more LEAKS in ATL parzam21 General Repair Forum 17 12-27-2015 02:46 PM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
