Old 03-26-2015, 11:44 AM   #1
2016 30' Classic
Sammamish , Washington
Window Leak?
My 2010 Classic Limited (27' Front Bedroom) is collecting water in the rear window channel (above the dinning room table). It appears to be coming in on the lower left corner between the window gasket and the window.
I need instructions on how to replace the gasket. The new gasket does have an adhesive strip. The issue is the corners. The corners require a 45 degree cut and the old gasket seems to have some sort of glue attaching the 2 pieces in each corner (except the lower left corner).
Any suggestions on adjusting the window latches for the "proper" tension would also be greatly appreciated.
Paul
PJohnson is offline   Reply With Quote
Leak then no leak. gandttimes Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-04-2013 01:34 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
Window Leak, All I Need is a Goldfish TOM CRUMP Windows & Screens 1 11-10-2003 06:49 PM
Window Leak, Any Advice? TOM CRUMP Windows & Screens 0 10-29-2003 06:40 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
