Old 04-25-2018, 07:30 AM   #1
1972 29' Ambassador
saint louis , Missouri
window gasket replacement
on my original gasket the butt joint is glued or welded? what is that? would silicone work on the new gasket?
trashbag is offline   Reply With Quote
Old 04-25-2018, 08:21 AM   #2
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
It is weatherstrip adhesive. When I replaced the weatherstrip on the windows on my '76, I used the adhesive to hold the weatherstrip on to the frames as well as the factory glue. Joins were done with adhesive as well. Not a big job!
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 04-25-2018, 09:28 AM   #3
1972 25' Tradewind
fort lauderdale , Florida
When I replaced my window gaskets, I wrapped the gasket around the glass and spring clamped it on each side of the seam. Then used a soldering iron to "weld" the two ends together.
ehodg66 is offline   Reply With Quote
Old 04-25-2018, 10:10 AM   #4
1972 29' Ambassador
that's what it looks like was originally done. I'm going to try that
Old 04-26-2018, 07:10 AM   #5
1972 25' Tradewind
It seems others on the forum have had no problem with there gaskets fitting correctly, but I had to make a "jig" to trim down the ribs off my gaskets because they really didn't fit. They were way too tight.
But, with a bit of Murphy's oil soap, a rubber mallet and elbow grease, we got them in.
Old 05-03-2018, 12:03 PM   #6
1972 29' Ambassador
last night I attempted to put window back together. wow that's tight. I might have to try trimming the ribs and lots of soapy water.
Old 05-03-2018, 02:12 PM   #7
1972 25' Tradewind
http://www.airforums.com/forums/f454...et-145394.html
1976 Argosy 26 Window/Door Gasket Replacement jebrant3 All Argosy Trailers 4 08-18-2016 10:35 AM
Idiot question on window gasket replacement drboyd Windows, Doors, Locks & Vents 3 10-19-2012 07:32 PM
Window Gasket/Seal - Help! Herm and Debby Windows & Screens 13 07-21-2003 01:54 PM
window gasket replacement JayClay Windows & Screens 3 05-05-2003 09:35 AM
Source for window gasket jaiman Windows & Screens 2 09-07-2002 09:16 PM
