1970
Sovereign, 31'. I've been chasing some leaks between the skin on the left front. It has four vista views that appear to have been problematic in the past and are now single pane. I've recaulked the vista views with vulkem and that appears to have done the trick. Installed new D-channel on the two moving windows as the PO did not use one continuous piece. Noticed that the opening windows have 3-4 weep-holes drilled, supposedly to let water out if it gets in the lower window channel between the window and the screen. I'm finding that the holes let more water in than out, with the possibility of leaking over the latch mechanism. Are weep-holes standard on these windows? I'd like to seal them up to keep water out.
