Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents
Old 09-28-2002, 11:00 AM   #1
Londoner
Profile:
weather stripping
I need to replace the weather stripping around the windows and doors of my '69 Overlander. Any advice about which product to use?
Londoner is offline   Reply With Quote
Old 09-28-2002, 11:08 AM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Use the original gasket that is still available. You can find it in our web site, inlandrv.com
Click on parts and then go to part number 45295.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 09-29-2002, 06:16 AM   #3
airstreamcaravel
airstreamcaravel's Avatar
Profile:
Stripping
Andy,
What would I use on a 1967 with the Cornings?
DMC
airstreamcaravel is offline   Reply With Quote
Old 09-29-2002, 11:30 AM   #4
Londoner
Profile:
Thanks for the info. So, it's the same stuff for the windows and doors?
Old 09-29-2002, 02:26 PM   #5
Commercial Vendor
Londoner.
The window and door gaskets are the same from 1966 to 1973.
airstreamcaravel
Same answer.
inlandrv.com
airstreamparts.com
Inlandrv.com
800-8777311
Old 10-05-2002, 08:57 PM   #6
Rob
Profile:
I ordered a bunch of the weather stripping frm Andy at Inland RV.
Got it via UPS a few days later. Did my first window today. It was easier than I tought it was going to be. The hard part is getting the adheasive off my hands. I'll use latex gloves on the next one.
The weatherstripping was reasonably priced too.
Next thing I'm going to do is pollish the frame before I put it back on the coach. Taking the window out is a must. Makes it easier to watch the game and polish at the same time.
Rob
Rob is offline   Reply With Quote
Old 07-13-2008, 06:47 PM   #7
skopp
skopp's Avatar
Profile:  2000 30' Excella
sun lakes , Arizona
I have a 2000 Excella with a front window that appears to have some cuts or holes in the D shaped weather stripping. Water gets in to the bottom of the window then gets inside. Can I use sealent on the weather stripping ? or does it have to be replaced. It looks like the stripping was cut at the window joint and water is seeping between the two corners.
Stephen C. Kopp
skopp is offline   Reply With Quote
Old 07-13-2008, 08:03 PM   #8
Commercial Vendor
Replace the gasket using one seam at the bottom center. You can make a small radius corner with the "D" gasket.
You can fuse that cut together with the super weatherstrip adhesive.
Sometimes, for whatever reason, the person that puts the gasket on the square cornered windows, at Airstream, leaves a lot to be desired when it comes to even a little craftsmanship.
The gasket does not cost much and neither does the black adhesive.
Inlandrv.com
800-8777311
[IMG] code is Off
window weather stripping edgybrown Windows & Screens 1 03-14-2004 10:32 AM
Somebody put some weather stripping... nds Our Community 7 01-23-2004 11:52 AM
Two ?'s Furnace and weather stripping escapeez Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-15-2002 06:10 PM
Need new weather stripping kit lizh Windows & Screens 8 08-30-2002 07:49 PM
Window Screen Weather Stripping ??? niftypkg Windows & Screens 0 06-03-2002 06:28 PM
