Old 08-04-2013, 03:26 PM   #1
Enthusiastic New AS'r
3campers's Avatar
1985 31' Limited
Glenville , New York
Images: 18
Water in my window?
One of my open-able windows has about a 1/4 inch of water in it. I can't find where it could have gotten in...no obvious entry point. And each window has what appears to be four small holes at the bottom which I assumed are drain holes. If they are, they are not working. How do I get this water out of my window? Thanks...
1985 31' Limited
2003 GMC Sierra HD SLT 4x4
3campers is offline   Reply With Quote
Old 08-04-2013, 03:44 PM   #2
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Drain holes being clogged - unfold paperclip, push up drain hole, unclog - water runs out! Better question - how did water get in - hard to clean in there. Need to seal around glass on outside.
Silver Hawk is offline   Reply With Quote
Old 08-05-2013, 10:49 AM   #3
3campers's Avatar
1985 31' Limited
Images: 18
Can't see where hole through window frame releases water in between glass panes? Not water in sill, water in between the glass pieces. I tried the paper clip and all it did was go through the frame. picture attached...
Name:	water in window1.jpg
1985 31' Limited
Old 08-05-2013, 12:00 PM   #4
3campers's Avatar
1985 31' Limited
Images: 18
After a bit of further investigation... I can't force a paper clip up through the gasket that is below the window and even if I could the hole would be so small it wouldn't likely let water out...it would have to be forced out. After looking around the web some more my only solution is to either live with it or do a window swap or remove the inner window and reseal...not swapping or removing windows...so this is the end of this story...
1985 31' Limited
Old 08-05-2013, 12:12 PM   #5
Rhino33's Avatar
1980 31' International
1966 22' Safari
Cincinnati , Ohio
We have this same problem with two of our un-openable windows. I'll try the paper clip tonight. Both windows had a thin white line of some caulk or sealant that was on the outside of the glass - any idea what we can use to reapply that?
Rhino33 is offline   Reply With Quote
Old 08-05-2013, 12:27 PM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Since it's an openable window, how far can you open it? Far enough to let the water run to the top of the pane? If so, the water might drain out with the window open through the same hole it got in.
Cats and ultraleather Airstream upholstery don't mix!
