Old 11-16-2007, 08:17 PM   #1
Gator1
Gator1's Avatar
2006 25' Safari
San Antonio , Texas
Vertical Shield on roof is broken
The vertically mounted sheet of metal between the refrigerator exhaust and the air conditioner on the roof came loose recently after I parked broadside to a stiff wind for a day.
It looks like this piece was just held in place with a seciton of double sided tape
I have the metal piece.
1. What is this sheet of metal for?
2. How do I best reattach it? Will double sided tape work? Rivets?
3. How criticla is it? DO I need to get it done before this week's trip?
Any help on this would be greatly appreciated.
2006 Safari FB25.
Jim Gompper
WBCCI #5228
2006 25' Safari FB
Gator1 is offline   Reply With Quote
Old 11-16-2007, 09:00 PM   #2
2005 31' Classic
Gretna , Nebraska
I'm sure it has to do with conntrolling the air circulation coming from the a/c so it does not interfere with the cooling of the fridge. How critical this is I have no idea. Perhaps some of our technical folks will shed some light on the issue.
Dwight Olson
Gretna NE
16595 is offline   Reply With Quote
Old 11-16-2007, 09:19 PM   #3
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
very critical to the refrigerator. Put it back on with caulking and pop rivets. The hot exhaust air from the ac will cause the refrigerator to overheat and fail.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 11-16-2007, 09:52 PM   #4
Gator1
Gator1's Avatar
2006 25' Safari
San Antonio , Texas
I'll get it back on!
Thanks to you both. I propably won't need A/C next wee, but I will get it back in place anyway.
Rick,
It's always nice to hear from Unit 111! We started there in 1999!
Jim Gompper
5228
Jim Gompper
WBCCI #5228
2006 25' Safari FB
Old 11-17-2007, 04:22 AM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The 2007 issue of the Blue Beret has an article from Airstream service section about this very problem. I suggest you get a copy of the BB and read it. You might want to contact the author in Jackson Center about your proposed repair methods.
Old 11-17-2007, 07:08 AM   #6
Gator1
Gator1's Avatar
2006 25' Safari
San Antonio , Texas
Blue Beret Article
Do you recall which issue this was in? I've been in the middle fo a military move this summer and fall and I haven't seen a Blue Beret in about three months.
Do you recall what their fix was?
***Late Addition***
I found the article on the WBCCI website! Thanks for the tip!
Jim Gompper
WBCCI #5228
2006 25' Safari FB
Old 11-17-2007, 10:01 AM   #7
1977 31' Sovereign
1989 34' Excella
It is in the issue that just came out. (November page 22.) Fred Ettline wrote the article (who is a club member) but the information was from John Husser WBCCI 17305. I am not sure who you would contact at the factory but call 937-596-6111 and ask to talk to Dave Schumann or one of his workers.
Old 05-23-2010, 03:04 PM   #8
Pappy's Avatar
2006 25' Classic
Floyds Knobs , Indiana
On my 2006 classic the Vertical shield between the AC and refrigerator vent is loose.
What was the fix for this? Mine has 3 rivets holding it down and it has become very loose and I believe causing a water leak.
Is it just a matter of drilling out the rivets?
Size of the rivets?
Use pop rivets?
Do I use 116 Vulkrem?
Thanks Pappy
Pappy is offline   Reply With Quote
Old 05-23-2010, 04:15 PM   #9
Pappy's Avatar
2006 25' Classic
Never mind
Size of the rivets?
Use pop rivets?
Thanks Pappy
Never mind, after digging through the sealent they are screws not rivets.
I suppose I will just get bigger screws.
Pappy
plastic shield for front window 66 overland Rock Guards, Segment & Window Protectors 4 10-06-2006 10:13 AM
early SS stone shield ticki2 Rock Guards, Segment & Window Protectors 1 09-30-2006 05:15 PM
Wind shield wipers on '75 Argosy abridges01 Mechanics Corner - Engines, Transmission & More... 9 09-10-2006 02:38 PM
Transit Shield exterior protection 63air Rock Guards, Segment & Window Protectors 1 01-21-2006 08:45 AM
Repair cracked rock shield? Rog0525 Rock Guards, Segment & Window Protectors 5 07-12-2003 12:53 PM
