Join Airstream Forums Today
Old 02-02-2012, 06:42 PM   #1
chrischarles's Avatar
1977 31' Sovereign
Jacksonville , Florida
Vents
This vent has an opening behind our fuse panel that is inside the front wall.
Is there suppose to be an aluminum screen there to prevent bugs and other things from getting inside? If so how is it attached?
chrischarles is offline   Reply With Quote
Old 02-03-2012, 06:00 AM   #2
blickcd's Avatar
Batavia , Ohio
That vent was originally for an enclosure which contained your Univolt battery charger. Assuming you no longer have your charger in an enclosure, you could seal it up.
I don't know if there was originally a screen there but I'd think that putting one on would be a good idea to keep out mud daubers and mice.
blickcd is offline   Reply With Quote
Old 02-04-2012, 06:51 AM   #3
1977 31' Sovereign
Thanks our charger was mounted to the floor right by the electrical panel. There were old wasps nests there and wanted to try and prevent any more from returning.
[IMG] code is Off
Info on '68 roof vents. Nomadtek Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-22-2011 11:47 AM
Removing vents? reddoor Ribs, Skins & Rivets 2 08-20-2011 06:42 PM
Cyclone Waste Vents onemanclan Plumbing - Systems & Fixtures 3 07-31-2011 05:22 PM
Why does 1 of my 3 vents look different from inside? bennyg Roof Vents, Skylights & Fans 4 06-26-2011 02:44 PM
Combining Black and Gray Roof Vents for 1958 mello mike Roof Vents, Skylights & Fans 5 02-06-2011 12:50 PM
