Old 06-27-2016, 01:22 PM   #1
okgypsy's Avatar
1966 20' Globetrotter
lexington , Oklahoma
Vent 911
I recently purchased a 1966 globetrotter. I need advice and or help on replacing the vent... I think this was a crank? Should I replace it as one or just install a sunlight? Also can it be installed through the ceiling or will I need to climb on top of the trailer? Click image for larger version
Name:	ImageUploadedByAirstream Forums1467055345.417871.jpg
ID:	265350 thank you in advance!
okgypsy is offline   Reply With Quote
Old 06-28-2016, 01:51 PM   #2
Central , Mississippi
It's really easy to install a Fantastic Vent, one of better types that are available and it comes with several options.
You will need to remove rivets and insert it from the top. The VAP podcast has some good advice on using some different screws than the ones that come with the fan.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 06-28-2016, 03:16 PM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
If you're going with a vent, look at MaxxAir Fans. They are far better than Fantastic Fans, IMO.
2019 Ford Expedition Platinum
Old 06-28-2016, 07:45 PM   #4
okgypsy's Avatar
Thank you!
Dometic Help...911 THEPILL Refrigerators 19 01-02-2010 01:53 PM
911 Help ~ when in the "sticks" CaddyGrn On The Road... 0 08-24-2008 10:04 PM
Remember...911.... canny_banjo_man Off Topic Forum 4 09-12-2004 07:24 AM
