Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents
Old 06-05-2014, 08:42 AM   #1
Justjanie56's Avatar
2012 30' International
Waxahachie , Texas
To tint or not to tint. That's the question.
We have a 2012 International Serenity & even with 2 ac units on top, it gets hot in the south! I've just recently added thermal liners (using Velcro for easy removal) to our very thin curtains but our big side windows only have roller shades & these get very hot. Should we attempt to remove the screens & add window tint film or is there a better solution? I'm wondering if removing the screens & reinstalling will cause problems down the road. All suggestions welcomed! Thanks.
Justjanie56 is offline   Reply With Quote
Old 06-05-2014, 08:45 AM   #2
Vycan's Avatar
1994 36' Classic 36 Diesel
Colorado Springs , Colorado
You can get a 'Low-E' tint at about 5% shading, almost completely unnoticeable. The 'Low-E' will reduce the energy transfer. It's worth a shot.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 06-05-2014, 10:25 AM   #3
Waxahachie , Texas
For inside window or outside window?
Old 06-05-2014, 11:46 AM   #4
r carl's Avatar
Lin , Ne
Try to always park under a tree to get the shade.
Old 06-05-2014, 03:46 PM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Excellent advice. The rooftop air conditioner will also be more efficient if the coils are in the shade.
But low-emissivity (low-e) film is also a very good idea. One caveat: Put the low-e film on the OUTSIDE of the glass to keep heat out. Low-e film gets hot to the touch when it blocks heat transfer, so if it's inside, it doesn't help as much.
Old 06-05-2014, 04:18 PM   #6
2005 19' Safari
GLENDALE , AZ
In a thread a year or two ago, a military contractor lived in his Airstream at a remote site at a military base in the desert southwest. He made cutouts from "sheathing" used in home construction, to fit in all of his windows and vents. Not sure, but he may have also covered some of the walls. Perhaps, he will see this thread and provide more details on how well this worked.
Sheathing is a relatively inexpensive, styrofoam sheet with a white plastic sheet laminated to one side and aluminum foil on the other. It comes in 4x8 foot sheets that (I think) are either 3/4- or 1-inch thick. They can be easily cut with a serrated knife or electric carving knife, although it is kind of messy; because the little styrofoam chips go all over the place, and they are charged with static electricity and cling to everything.
This extra insulation helps quite a bit, because a lot of the summer heat gain is through the windows. Unfortunately, this will also turn your Airstream into a dark cave; so you will have to decide if being cool is worth sitting in the dark all day.
Old 06-05-2014, 06:13 PM   #7
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
I purchased several of the solar windshield shades (silver bubble pack material) and cut them out to the shapes of the windows. I used small round double stick clear velcro dots to attached them to he outside edge of the window frame. For the roof portals, I placed the solar shares next to the glass and then closed the pleated shade over them. Cost effective and works very well. Takes very little storage when not in use.
tsunami is offline   Reply With Quote
Old 06-05-2014, 08:32 PM   #8
Waxahachie , Texas
So much good advice! Thank you y'all so much.
To tint or not to tint. Kreimer Windows & Screens 17 05-23-2012 02:24 PM
Land Yacht windshield tint gunworks Land Yacht/Legacy Motorhomes 10 06-04-2009 04:23 AM
what can happen when you tint your windows remcolent Windows & Screens 12 11-19-2006 03:30 PM
replacing window tint Angel73 Windows & Screens 2 05-23-2006 08:13 AM
bad tint film in double pane window wcdelorme Windows & Screens 11 05-16-2003 01:53 PM
