Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents
Old 10-04-2014, 02:50 PM   #1
Conroe , Texas
Steps "frame" by the door.. Help please!
Not exactly a door problem, but I wasn't sure where to put this question, so here it goes.
That frame what it holds the steps in my 1973 Argosy, the right side totally rusted, and cracked. I removed the steps, and wondering if is available to order that "frame"?
I don't know anyone around here who has a welding/machine shop, because I thought it is possible to cut it out a lower part (marked with red dots) like a triangle, and just weld it back a sheet of metal, and paint it over.
The steps can't slide in , and out freely anymore because of the rusted part.
The left side in good condition:
The right side again:
a_magyar is offline   Reply With Quote
Old 10-04-2014, 03:07 PM   #2
Always learning
Lance M's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Lance M
Outrigger for step attachment LH 410524 [410524] - $24.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Lance
Lance M is offline   Reply With Quote
Old 10-04-2014, 03:08 PM   #3
terryV's Avatar
2002 31' Classic
Monroe , Iowa
If you can buy the "frame" it would probably be the best fix.
However, if you can't, you should be able to find a good local auto body shop to make a piece and weld it in.
terryV is offline   Reply With Quote
Old 10-04-2014, 03:28 PM   #4
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
Try either out of doors mart or Silver Trailer Supply. I think both will have that "outrigger"
My 57 Overlander thread ( Holly is her name)
https://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 10-04-2014, 03:41 PM   #5
batman's Avatar
1964 22' Safari
modesto , California
Keep the original. I had the same piece cut and welded for the step on my Safari, it came out great. It looks all original nothing after market. If you can't find a welding shop, terryv had a good Idea try a body shop, or even a metal fabricator near by. If you buy an after market step, i suspect you will have to get the old one cut out, and the new one welded in place by some one. Look up mobile welding, there may be some one in your area. My .02
batman is offline   Reply With Quote
Old 10-04-2014, 06:29 PM   #6
Conroe , Texas
Thank you guys! I just ordered one, and my buddy will help to weld it in
Beatrice era frame experts if you please. Odd frame issue Kevin245 Repairing/Replacing Floor &/or Frame 5 08-25-2012 09:55 AM
Removing Steps Channel: Must remove Door frame first? jhbaron Doors & Locks 0 02-14-2012 05:12 PM
PLEASE HELP...Cast aluminum door frame problem. WILDRTEXAS Doors & Locks 16 05-04-2011 03:22 PM
