Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents
Old 08-27-2008, 04:14 PM   #1
Profile:
Stain on inside of door
does anyone know how to remove rust-colored stain from inside of door? Cleanser with bleach, mildew remover and Krud Kutter all tried, with no success. What causes this? It was only on bottom, now it looks like stain has pattern of screen shield.
smokeysmom is offline   Reply With Quote
Old 08-27-2008, 04:22 PM   #2
Ed Emerick's Avatar
Profile:  1968 30' Sovereign
1959 18' "Footer"
1954 22' Flying Cloud
Appleton , Wisconsin
Clean
Try awning cleaner, it cuts through most stuff I have run into.
Ed Emerick is offline   Reply With Quote
Old 08-27-2008, 06:37 PM   #3
Profile:  1990 34' Excella
Parsonsfield, , Maine
I assume that your trailer is a 70' thru 90' model year. I have observed this condition mostly on trailers that have been lived-in during winters in southern climates where the doors are left open a lot with the sun hitting on the inside skin of the door. I believe that the cause is the sun and heat from the sun has drawn elements of the glue, or contact cement that binds the vinyl finish, through to the inside surface of the vinyl. I painted mine with an acrylic paint. Another solution is to find a dealer who has some of that inner skin with the bonded vinyl surface. Then remove the pop rivets and use the old inner door skin as a pattern to cut the new skin to fit. CharlieE
CharlieE is offline   Reply With Quote
Old 08-27-2008, 07:46 PM   #4
94Tri's Avatar
Profile:  1994 34' Excella
Mount Vernon , Kentucky
Welcome to The Forum. Sounds like you have already received an answer to you problem. A lot of great minds at work here.
94Tri is offline   Reply With Quote
[IMG] code is Off
Light switches on the inside door mebbecky Lights - Interior & Exterior 17 08-06-2008 07:06 AM
Door will not lock from inside. mello mike Doors & Locks 2 07-31-2007 08:30 AM
Gasket on door or inside of door? beckybillrae Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 07-06-2007 02:06 PM
72 Tradewind: Locking the Door From Inside yochanan Doors & Locks 2 11-05-2005 08:25 PM
Inside door handle for a 1984 International Bennie 1980-1984 International 0 08-06-2002 09:37 PM
