Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents
Old 05-27-2009, 08:01 AM   #1
mello mike's Avatar
Profile:  1972 31' Sovereign
Phoenix , Arizona
Images: 14
Question Spring loaded, Vintage Black Door Latch Question
I've searched the forums on how to assemble and dissemble these spring-loaded, black latches and all I could really find was how to take apart tbese things. My problem is I have two of these latches on the exterior with the bottom piece still intact (one on the rear bumper door and one on the main entry door) and I would like to repair these. I have 4 replacements so I'm good to go.
How do you put these blasted things together? There has to be a trick because my springs either end up flying vast distances or get bent.
Sterling - 1972 Sovereign Intl (RB)
Eddie - 2003 Ford Excursion (6.0L PSD)
Prodigy Brake Controller / Equal-i-zer Hitch / Honda EU2000i x2
Airstream Life Contributor
WBCCI 4CU #5661/AIR #5661
My Refurb Blog: UPDATED!!
http://mellomikesairstreams.blogspot.com/
Part wanted: 70s Kitchen Counter Unit
mello mike is offline   Reply With Quote
Old 05-27-2009, 10:37 PM   #2
mello mike's Avatar
Phoenix , Arizona
Images: 14
Okay, I've solved the mystery. My new latches don't fit together exactly. The base piece requires a little filing for the top piece to fit it properly. If anyone is interested let me know and I'll tell you the details.
Old 05-28-2009, 08:19 AM   #3
Profile:  1974 31' Sovereign
beautiful downtown Aurora , Ontario
Send a message via ICQ to Aage
If by the base piece you mean the metal cover, it fits perfectly together on my new one, but it only goes on one way.
If yours doesn't, try taking it off and rotating it 180 degrees.
The road to a friend's house is never long. (Old Danish Saying)
Old 05-28-2009, 01:13 PM   #4
mello mike's Avatar
Phoenix , Arizona
Images: 14
Aage, you're referring to the new style, metal cover door latch. I was talking about the black plastic, spring loaded latch found in 60s and 70s Airstreams.
Old 05-28-2009, 02:25 PM   #5
Uh-huh, OK. The one Im talking about is black plastic with a spring and metal cover, and it appears to be OE for my '74. It's used both to fasten the outer door to the body while using the screen only, and a second one to fasten the screen door to the outer door to make them operate as one.
Don't think I've seen the one you're referring to.
Old 05-31-2009, 08:25 AM   #6
mello mike's Avatar
Phoenix , Arizona
Images: 14
Here's a pic of two of these vintage latches I repaired.
Aage, I don't think the latch you're referring to is OEM. I could be wrong, though.
Old 05-31-2009, 08:38 AM   #7
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
This the latch on my 75. I have replaced it once after it froze last year and broke when the door was opened. You can replace the plastic piece and spring and / or the outer shell. The parts are available from several popular locations.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 05-31-2009, 08:36 AM   #8
Jim & Susan's Avatar
Profile:  1973 27' Overlander
McDonough , Georgia
Mike, where did you find the OEM type latch parts? The only replacements I've found are the metal encased type the Aage is referring to.
JIm
Can somebody remind Susan that I really do want bagpipes for Christmas?
www.nesa.org
Air No. 6427
Old 05-31-2009, 10:55 AM   #9
mello mike's Avatar
Phoenix , Arizona
Images: 14
JIm
Hi Jim,
I bought my latch replacement parts from Oasis RV in Tucson. I also salvaged two complete latches that were part of an old overhead storage tub. These parts are no longer made but you can still find them if you look hard enough.
Some 1970s Airstreamer owners may not know this, but these black, spring loaded latches are found on the inside of each cabinet door. These latches were used on both the inside and outside.
Old 05-31-2009, 11:02 AM   #10
cameront120's Avatar
Profile:  1972 25' Tradewind
I've managed to get mine back together without any filing. It's a bit fussy, but they do go together.
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
cameront120 is online now   Reply With Quote
Old 05-31-2009, 11:35 AM   #11
mello mike's Avatar
Phoenix , Arizona
Images: 14
Yeah, when I said that I was referring to the new latches I bought. The old ones go back together with no problem.
Old 05-31-2009, 06:50 PM   #12
Phoenix , Arizona
Images: 62
I have 2 of those latches/ One to hold the screen door to the main and another to keep the lab from opening the screen door. VTS sells them for around $9.
Richard
[IMG] code is Off
What do you call the little flat latch with a spring? Zstream General Repair Forum 8 04-27-2008 09:16 PM
Vintage Airstream window latch TOOL NEEDED mediaetc Windows & Screens 6 06-29-2007 01:45 PM
Dometic 2800 door latch spring artnsue Refrigerators 1 04-24-2007 05:54 AM
Black rubber T-handle hold-down, latch iowaroots The Vendor's Forum 0 09-10-2004 09:33 AM
Loaded question: avg miles per set of brake pads John Brakes & Brake Controllers 2 12-12-2002 06:01 AM
