Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents
Old 11-16-2013, 01:48 PM   #1
deauxrite's Avatar
2007 27' Safari FB SE
Full Timers just passing through , Arizona for a couple of weeks and then on to Utah!
Skylights, leaks and poor workmanship
I just replaced the skylight on our 2007 Safari. I replaced the original with a Maxim and could not be happier with the quality of the replacement skylight.
I have nothing good to say about the installation of the original. In fact, I have attached some photos that show just how bad the original installation was. I did some minor damage to the skylight in taking it out, but as you can see, every single screw was over driven and cracked the skylight in every hole. Checking inside, there is some evidence of water intrusion, which would explain why we had some small water leaks in various places.
There were three places on the skylight that the screws were broken off during the initial installation..and just caulked and left.
I offer these photos and this thread for those that might be having leaks that they just cannot track down. I suggest that you get on top of your trailer and have a look at the skylight. I will bet that the installation is similar to mine..terrible!
ID:	200127   Click image for larger version
ID:	200129   Click image for larger version
Living life on the Road
deauxrite is offline   Reply With Quote
Old 11-16-2013, 03:56 PM   #2
2012 30' Classic
Wildwood , Missouri
We've had leaks too. We took our Airstream to the dealer and they caulked different areas (looks like crap) and told us our skylights were cracked and needed to be replaced. We have indoor storage for the winter, but next spring, we will replace with the Maxims too. How difficult was the process?
kswelsh is offline   Reply With Quote
Old 11-16-2013, 04:06 PM   #3
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
New ones look better
We have a 2013 25FB (made this April). The skylight material looks like yours, but it appears to be installed with double side tape--no screws. So no cracks from exuberant installers.
Some day I expect the plastic will succumb to UV rays, and then it's be a pain to get the original one off and the tape cleaned up. But we can hope that challenge is years away.
SSquared is offline   Reply With Quote
Old 11-16-2013, 04:20 PM   #4
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Beyond me why AS installs crap like this.
Ours were leaking and when I looked to find the cause, I found that almost every screw through the cheap plastic skylight flange had cracks emanating from it in the flange.
Possibly if AS had not tightened the screws so much this might to have happened, but I suspect it still would as the original skylights were brittle and useless.
Since replaced with Maxims - perfect now.
I gather that in their wisdom, AS's solution was to continue using the cheapies, but to use double sided tape instead of screws.
Perhaps it is better - but I have heard of these taped-on ones coming loose and leaking and some owners have resorted to changing them for after market units also.
No doubt the company's bottom line is as important to AS as it is to any other company, but is this any way to achieve the image of being the best RV on the road?
Perhaps that is not their goal.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 11-16-2013, 05:23 PM   #5
"Cloudsplitter"
Thumbs up
Check everything on the roof with caulk on it....AS workers have never figured out how to install anything up there.
Notorious for cracking Fantastic vents also, luckily FF replaced both ours under their warranty.
Black tank vent right off the line....
My repair the first week of ownership.
Name:	SOLAR PANELS; ROOF LEAK 011.jpg
Old 11-17-2013, 06:17 AM   #6
deauxrite's Avatar
To the question of how difficult it was to replace? The labor part of the project is pretty simple. Removal and clean up of the old skylight is time consuming (2 hours) due to the amount of caulk that the factory used on the original. Once cleaned up and ready for installation..simple and easy and no more than an hour to install the Maxim. I used a putty knife, rag and Acetone for the cleanup work.
The only issue on my trailer (07 Safari) is that the distance between the skylight and the air conditioned shroud prevents getting a drill in there to install the screws on the forward side. I used a 90 degree offset drill to do that job (not something that everyone has in the tool bag). Just be sure to look at it and plan accordingly if there is anything that will prevent getting a drill in position to install the self tapping screws into the Maxim. (#10 X 1/14 with rubber gaskets available at Lowes)
I looked at all of the information available here on the air forums before I started the project and found all of the advice to be excellent!
Old 11-17-2013, 12:25 PM   #7
2001 30' Classic S/O
Salida , Colorado
I am reading this thread with much interest since I am now in rainy weather and have leaks. Carpet wet around front door area, and sometimes a small puddle on the table of the dining area. Both near the front skylight. A visual inspection from a ladder shows the kind of worn and aged skylight in these pictures. I have a 2001 Classic SO.
So my concern is that crawling and working up on the roof might break loose some of the other old seams up there and cause more leakage even after the skylight if fixed. Should this be a concern? Thanks. Casey.
Colorado Casey is offline   Reply With Quote
Old 11-17-2013, 12:37 PM   #8
Wingeezer's Avatar
2005 30' Classic
I don't think it should be a concern. Just stay on the rivet lines.
I went up on our roof and gooped up all the cracks in our original skylight flanges that were leaking with a clear flexible sealant (Storm King) and it did stop the leaks. But shortly thereafter I decided to do things right and replaced the skylights with the Maxim ones.
Brian.
2005 Classic 30'
Old 11-17-2013, 01:06 PM   #9
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Here's a long thread about bad skylights and replacing with Maxim. I bought a replacement kit from a reputable online vendor but when I saw the Maxims I skipped the halfway step and ordered Maxims and had vinnie install them. They are great and no more worries about skylight leaks. They also cut down a lot on heat transfer. - Brad
http://www.airforums.com/forums/f455...hts-53517.html
SuperTrouper is offline   Reply With Quote
Old 11-18-2013, 06:25 AM   #10
Salida , Colorado
OK, thanks for the good replies. Since I am on the road I think I will go the goop up the old skylight route for now, and when time allows replace both of them with the great looking Maxims. Casey.
Old 11-18-2013, 07:55 AM   #11
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Do you have any pics of post installation?
I'm curious what specifications the new skylight had.
Was there a certain level of tinting requested? What were the options? Is this an expensive repair?
I am asking because I am anticipating this project next year.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 11-18-2013, 10:46 AM   #12
Wingeezer's Avatar
2005 30' Classic
Here is a link to their website - there is a section on Airstream trailer applications.
Products - Maxim SkylightMaxim Skylight
They did have a couple of pictures of our trailer on there at one time - not sure if still there.
The skylight uses a substantial welded aluminum frame and the skylight itself is three layers of polycarbonate - not acrylic - relatively hail proof.
If I recall, it cost us maybe $450 total for the two skylights. I arranged to pick them up in Dallas on our way home from Arizona, otherwise there would have been a substantial crating and shipping charge.
Installation was a breeze, most of the work is in cleaning away all the old caulking and bits of broken plastic skylight flange.
There is a choice of anodized aluminum finishes and different tints - you can select what you want for each layer.
If I recall, I went with top layer bronze then two layers clear - we still wanted to get a fair amount of light in.
Very happy with the results in every respect.
Brian.
2005 Classic 30'
Old 11-18-2013, 11:30 AM   #13
dznf0g's Avatar
Oswego , Illinois
i went with Bronze/clear/clear. Folks in the SW will commonly go with bronze/bronze/clear due to their intense sun..but it is pretty dark with 2 bronze layers.
IIRC, it was about $420 for both skylights on my classic and a snap to install. Very nice quality with Maxim, and they are familiar with AS sizes and fitment.
-Rich-
Old 11-18-2013, 01:11 PM   #14
We got white frosted / clear for more even light over the longest period of time during the day.
Looking for adventure in whatever comes our way.
- Brad
Old 11-18-2013, 01:17 PM   #15
1981 31' Excella II
New Market , Alabama
Don't put plastic on your roof. It will rot in 10 yrs or less. The screws would have cracked the plastic no matter what. The metal frame metal lid vents that were on the older Airstreams were the best design accept for the plastic insert that rots out and leaks. Plastic vents were a constant maintenance item on RV's when I was growing up and we always had some sort of leak and rotten wood as a result.
Perry
Old 11-18-2013, 01:44 PM   #16
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
how reliable are these rain sensors....the idea of leaving them on and running is attractive to keep moisture down when stored to some degree...but if that sensor fails to work....well that would suck...how reliable is that feature?
The simplicity of the maxair fans seems logical....I hope mine were not damaged in install...
PharmGeek is offline   Reply With Quote
Old 11-18-2013, 01:49 PM   #17
1981 31' Excella II
Like anything you have to check them and replace batteries.
Perry
Old 11-18-2013, 01:54 PM   #18
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I replaced the factory sky lights with Maxim's.I am glad I did as the leaks were not visible until I removed the factory plastic ones(cracked at every hold down screw).Big difference in quality with the Maxims.
This would be my first mod with a new Airstream.
Old 11-18-2013, 01:58 PM   #19
Wingeezer's Avatar
2005 30' Classic
We have two Fantastic Fans in our trailer and whenever I have had them running, they have never failed to close automatically if it started to rain.
But even so, if there looks to be any chance of rain and we are going to be away from the trailer, I always close them down - no point tempting fate!
Personally I would not take a chance on relying on them when the trailer was in storage. But that's just me - always the pessimist!
We couldn't do it anyway as we have no power and remove the coach batteries when we store our trailer
Brian.
2005 Classic 30'
Old 11-18-2013, 02:21 PM   #20
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
we are managing 15amp basic power needs right now...spring we will install our electric 50amp hookup...in theory, it seems a great thing to be able to exhaust heat/moisture from the AS while in storage if possible....but not at a significant risk of leaking...
If no one has confidence in this feature, then what good is it? The rep at the dealer who did walkthrough gave me caution about the one in the back above the bunk room...said she has heard a bit too often of the rain sensor failing and getting water on the bed....im not sure which would be worse....water coming in on bed or in the middle of the floor.....
If I cannot feel confident in these fans, then I will certainly be examining changing them as IF keeping moisture and excess heat down is a helpful long term moisture management strategy, then it may be worth the fuss...
I will need to do alot of research and think about this...would not be able to think about such a change till next springe...money tree is dry...
I guess I am hoping for the pro-fantastic-fan folks to start to come out of the woodworks to tell me otherwise..
I also now need to dig through old posts about storage, venting, dehumidifiers.....later...
Hate to hear about bad quality...hope yall get it figured out and hopefully this info will prevent my own headaches
