Old 08-07-2014, 09:17 AM   #1
2014 27' FB International
Santa Rosa , California
Shower Door Issue
We have a 28' International, 2014. The Shower door has slipped down in the hinge requiring one to lift the shower door up to open and close it. The dealer says that the mfg states 1/4" tolerance/slippage is to be expected. I am pretty sure that this is not the answer. Any suggestions? BTW, has anyone replaced frosted shower door with clear glass option (non-Airstream after market)? Thanks
NatandGregg is offline   Reply With Quote
Old 08-07-2014, 09:29 AM   #2
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
I know you're thorough, but I want to check - is the trailer leveled when doing this test? On my 2011 intl 28, if I am off level either direction, the door behaves differently with it's sticking points (off level with the curb side higher requires on to life the door to get it closed. Even level, it works fine.
2011 Airstream International Serenity 28' - 30a/taupe
2013 Fors F150 v6-ecoboost with max tow and HD payload packages
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Old 08-07-2014, 09:41 AM   #3
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
My shower door is complete garbage (2005 classic). All the adjustment screws have loosened. The latch is a piece of Sh*t. the plastic threshold fell off.
It is one step away from falling completely out of the frame. I suggest getting out the toolbox, some locktite, and some silicon and spend a couple of hours rebuiding and remounting. That's my plan.
Ugh.
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 08-07-2014, 10:53 AM   #4
1974 Argosy 20
Kooskia , Idaho
On a 2014, under warrantee, with an un corporative dealer, I would place a call in to the factory for assistance. Let Airstream deal with their dealers who are not helpful.
Old 08-07-2014, 10:57 PM   #5
Thanks for the confirmation and advice, I will proceed with the factory and other options including taking it apart
Old 11-17-2014, 05:59 PM   #6
2012 25' FB Eddie Bauer
2009 19' International
Aptos , California
Late model shower door fix
I had the same problem with the shower door on my 2012 25' Eddie Bauer. After several good hearted but only temporary fixes by the too-far-away dealer, I came up with a fix that works.
There seems to be no way to adjust the height of the door using any easily accessible adjustment screws. Instead, I decided I would have to shim the thing. I wandered around a home depot one day looking for stuff that might serve as shims. I took home nylon washers of various thicknesses and diameters, bought lengths of likely looking hardwood dowels, even a package or two of those hardwood inserts used in cabinet making to fill in screw holes.
By chance, I also took home a package of a half dozen magnets that were about the size of a nickel. A stack of three of them turned out to be the right thickness. They were magnets, so they stuck to each other. Better yet, the metal surround of the shower door has enough ferrous metal that the magnets snapped into the inner recess of the door below the hinges at exactly the right point to support the door. After many miles on washboard Canadian forestry roads, the magnets are still in place and the door is no problem.
The magnets cost about $4.00. All of the stuff I bought that day cost less than $15. Gas to the dealer and back would have been about $75. And I don't think they've got a solution this cool.
brad1 is offline   Reply With Quote
Old 11-17-2014, 06:37 PM   #7
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Sadly, your dealer is unimaginative and possibly lazy. We have a 2014 Eddie Bauer and had the very same problem. We took the trailer to the factory a week ago for a variety of minor tweaks and the drooping shower door was among them. Our excellent service tech (Garrett) fashioned a small shim with a plastic block and screwed it in place. Take this image to your dealer and challenge him to be a bit more creative.
Bob Martel
WBCCI# 5766
Old 11-17-2014, 06:38 PM   #8
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
We had the same problem. My husband made a nylon shim that he glued on the thresh hold and it keeps the door from sagging.
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
Old 11-17-2014, 08:02 PM   #9
2020 Classic 33 on order
Box Elder , South Dakota
On my 2014 FC door dropped so badly that the adjusting screw at the top was bent. After replacing the entire door and frame the factory tech did the same thing with a shim block. On my upcoming Classic I may even stop at the factory on the way home and get one installed.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NŘVPN
ghaynes755 is offline   Reply With Quote
Old 11-17-2014, 10:08 PM   #10
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
I think I had my trailer in to the dealer four times before they came up with a fix like the Martel's. I still tear the seal flap off occasionally.��
Old 11-18-2014, 07:34 AM   #11
Thanks to all of you. We gave up on shims and the dealership and replaced it with a proper shower door, clear glass. I am not sure how to post a picture of it, but it turned out well. It was $500 for the install and looks great.
Old 11-18-2014, 12:19 PM   #12
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
This is a well-known issue. My 28' 2012 Intl CCD had exactly the same problem. The issue is the cheap little pot metal screw that's supposed to hold the door up (this screw is at the very top of the door frame). It breaks, and when it does the whole door slides down. After several "rigged" solutions, I ripped out the entire shower and used a Kohler Sterling that pivots. Problem solved. Shouldn't have had to do this, but like several hundreds of other owners.....
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 11-19-2014, 06:35 AM   #13
2004 28' Classic
austin , Texas
Nate and Greg....where did you get the new shower door? Who installed it? Did you replace the frame too? Or only the door? I am very interested in replacing ours on our 2004 28ft classic. I have switched out all of the other bright brass items that make the trailer look dated, except for this door. In addition, the latch is broken and they say it cant be fixed...parts not available anymore.
Ntex is offline   Reply With Quote
Old 01-12-2015, 12:20 PM   #14
2010 30' SO Classic
Mohawk , Michigan
Shower door wiggles like a wet dog drying itself off every time it is opened - no wonder adjustment screws work themselves loose! We've learned to live with it, tightening as you go. Magnetic strip occasionally falls down and out of its space, we jam paper up behind it to keep it from falling out. At least it doesn't leak.
radargeek is offline   Reply With Quote
Shower Curtain or Shower Door for 1972? mello mike Sinks, Showers & Toilets 26 04-02-2017 09:10 PM
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
Accordion Door Warranty Issue? wayner61 General Interior Topics 12 07-04-2009 01:51 PM
Vintage '70s Shower Door and Water Heater Door -- Freebie maccamper General Repair Forum 6 05-15-2009 09:18 AM
Door Issue dezelfeder Doors & Locks 7 11-25-2006 10:54 PM
