Old 12-03-2017, 12:53 PM   #29
casarodante's Avatar
2012 31' Classic
Our 2012 Classic 31 had a screw completely let go of the frame. This let the door fall down but did not break. Out of warranty, of course, so I went with a solution I used in our '92. A replacement shower door called a SHUB: https://www.newlinebathroom.com/shub...boats-c-1.html
Roger & Roxie (rore62) Smith (Air#178 - WBCCI#1646)
On the road!
2012 31' Classic - Nuestra casa rodante
Blog: https://www.casarodante.org - Old Airstream slides: https://airstream.casarodante.org
casarodante is offline   Reply With Quote
Old 12-03-2017, 04:02 PM   #30
prostar's Avatar
2014 28' Flying Cloud
Allen , Texas
My fix for now Nylon spacer from Lowes
Name:	Shower Washer 01.jpg
ID:	300273   Click image for larger version
Name:	Shower Washer 02.jpg
2014 Flying Cloud 28
2007 Chevrolet 2500HD
WBCCI#8934
prostar is offline   Reply With Quote
Old 04-02-2018, 10:38 AM   #31
wecoyote's Avatar
2014 30' Flying Cloud
Royal Oak , Michigan
For everyone who has used the nylon spacer as a fix, what do you do to prevent the rough edge of the aluminum frame from chewing up the top of the nylon. Our favorite dealer replaced put the aluminum spacer with a plastic top under the hinge and it works fine for a while. Once the plastic wears off, the door drops back down and is difficult to open and close.
What about a nylon piece at the bottom of the door itself and another on the threshold. Then, it is nylon against nylon...
Royal Oak, MI
WBCCI #: 8356 (the same number my grandparents had from 1963 to 1981)
AIR #: 104322
Henry - 2013 F150 Super Crew XLT w/ HD Towing
wecoyote is offline   Reply With Quote
Old 04-04-2018, 09:29 AM   #32
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
After rebuilding mine, we installed a new door same thing, i now put rubber hose under the door when moving, 5/8 silicone 1 1/2 “ long...no more problem
Old 04-04-2018, 10:37 AM   #33
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I made my spacer out of a piece of plastic cutting board. I sawed a groove in it to fit the ridge in the threshold to keep it in place. Sorry the photo is rotated 90 degrees counterclockwise.
I haven't noticed any wear.
2019 Ford Expedition Platinum
Old 05-16-2018, 01:36 PM   #34
2012 31' Classic
The Villages , Florida
After 5 years of various supports and two major repairs I finally came up with a 1" long piece of aluminum that I glued in place with silicone. The piece must be long enough to not only support the vertical piece of the frame, but also support the bottom cross piece of the door. The support keeps the plastic hinge from breaking and the support under the cross piece keeps the screws from sheering off. I am attaching three pictures of the block in place. OOPs..I can't figure out how to insert pictures. I will work on that.
Uncle Bill is offline   Reply With Quote
Old 05-16-2018, 01:49 PM   #35
2012 31' Classic
Got it, here are the pictures
Name:	2017 Door Support - 1.jpg
ID:	311123   Click image for larger version
Name:	2017 Door Support - 2.jpg
Name:	2017 Door Support - 3.jpg
Shower Curtain or Shower Door for 1972? mello mike Sinks, Showers & Toilets 26 04-02-2017 09:10 PM
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
Accordion Door Warranty Issue? wayner61 General Interior Topics 12 07-04-2009 01:51 PM
Vintage '70s Shower Door and Water Heater Door -- Freebie maccamper General Repair Forum 6 05-15-2009 09:18 AM
Door Issue dezelfeder Doors & Locks 7 11-25-2006 10:54 PM
