Old 07-07-2014, 07:06 AM   #1
1975 31' Sovereign
Punta Gorda , Florida
Sealing windows...
Hello all, I am in the process of a renovation and want to seal all my windows, primarily the upper windows that seem to be my problem. Any tips on accomplishing this, and also removing silicone that the previous owner sealed the windows shut with
meswoss is offline   Reply With Quote
Old 07-07-2014, 08:17 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
The silicone will require a good bit of elbow grease to remove. Do a search for "remove silicone" on the forums, and you may find some suggested chemicals to aid the effort.
The windows are mounted in the moving frames with a little rubber seal that will have dried out and hardened by now. I tried to find a replacement for these and was unsuccessful, so trimmed them flush with the window frame, then ran a bead of vulkem at the interface of window frame to glass. The soft rubber gaskets that seal the moving frame to the stationary frame are still available from suppliers like Inland RV and Outofdoorsmart.com. Be sure to order the 3M gasket glue to glue the new seals in place.
good luck!
Sealing the Vista View Windows Gkiesel Leaks - Weatherstrips, Gaskets, Caulks & Sealants 22 10-12-2017 11:42 AM
Need Advice: Re-Sealing Windows & Replacing Table SueH Member Introductions 6 11-30-2006 03:35 AM
Windows, windows, windows... Balquin Windows & Screens 4 07-04-2006 06:35 PM
Use of Vulkem for sealing windows... TheCountess Windows & Screens 8 05-22-2006 07:43 AM
Sealing Windows & Caulking outside mgordon Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 01-13-2003 12:18 PM
