Old 11-12-2005, 06:14 PM   #1
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
sealer along window edge?
Hi,
I was just out cleaning my interior window frame and a big strip of clear-colored sealer of some kind peeled right off. Here's a picture of the window and where the stuff was. It's not a window that opens, but the window above it does, so I'm assuming some water will get in if I don't squirt some new stuff in there.
Does anyone know what it might have been and what I should put back in? Is it that Vulkem stuff, Sikaflex, or something else?
Thanks...I'm also going to post a wish list of small window parts in case anyone has them for my '67.
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 11-12-2005, 06:29 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Ingrid,
If it was clear and could be peeled off it more than likely was silicone ...I would go back with Vulkem it if were me.
Aaron
WBCCI #XXXX AIR #2495
Old 11-12-2005, 07:16 PM   #3
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Ingrid,
You will need to clean the area thoroughly with something like Acetone to make sure there is no trace of silicone left. If not, the Vulcum or Silkaflex will not adhere to the surface correctly.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 11-19-2005, 07:05 AM   #4
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Silly Cone
Ingrid, My Curb Side Window Is Just Like Yours, And Also Like Yours My Po Also Sealed It Up With Gobs Of Silicon Sealer! Get A Good Plastic Paint Scraper And A Small Brass Wire Brush And Remove All That Goop, Then Clean The Window/frame Area Throughly With Acetone And Reseal With Vulkem. Use The Same Plastic Scraper/putty Knife To Force Vulkem Down Into The Gaps Between The Glass And The Frame And You Will Get A Water Tight Seal That Looks A Lot Better Than What You Had Before. Ed
BIGED52 is offline   Reply With Quote
Old 11-19-2005, 03:47 PM   #5
1967 24' Tradewind
Images: 38
Once again, forums to the rescue. I did buy some grey Vulkem, and will clean it and re-seal. I also went over to the other side and peeled off another rubber worm of sealer over there. My windows are going to be in tip top shape when I'm done...thanks guys!!
~ Hurley
ingrid
Old 11-19-2005, 07:59 PM   #6
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
Ingrid, I don't suppose I've told you lately how GLAD I am that you are going through this stuff before me. I learn so much from your threads!
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
Old 11-19-2005, 09:57 PM   #7
CanoeStream's Avatar
St. Cloud , Minnesota
The product name is Sikaflex-221
Long before I learned how to work with Airstreams, a coworker owned a Cadillac runabout. This was a small aluminum boat with a front deck and windshield. See: http://www.harborrec.com/CurrentPics%5C049.html. A quick Google produces production dates in the 1950s. The sealant between the panels had long since worn out and it would sink every night if he left it tied to the dock. More than once he cleaned up the joints and caulked it with silicone. I don't know what he did with that boat but the silicone never did the trick. Silicone does not adhere to the oxided aluminum surface at all -- well, let's just say it doesn't seal very well. You'll hate having to remove the stuff!
There are countless threads on Vulkem or Sikaflex if you use the search function. Vulkem has good body and gap filling characteristics, but it is lumpy and works well if a smooth appearance is not your objective. Vulkem remains tacky for a long time. Sikaflex 221, http://www.sikaindustry.com/tds-ipd-sf221-ind-us.pdf, is also a good product for aluminum applications. It is smooth textured and skins over in a fairly brief period -- a couple hours or so. I really like it for more finished applications.
It is rare you use a whole caulk tube of these products. Put aluminum foil over the tip and wrap it in a couple of bread wrappers bound with rubber bands, then store the whole thing in the freezer. My wife takes to that a lot better than when I used to keep birdwatching specimens on ice...
5 meter Langford Nahanni
Old 11-19-2005, 11:10 PM   #8
1967 24' Tradewind
Images: 38
vulkem/sikaflex
So...for the application I need it for, do you recommend Sikaflex over Vulkem? I'm sure I'll use the Vulkem I ordered for something else; we're re-doing the whole trailer. It sounds like you're saying they both work well, but Sikaflex is easier to deal with and dries more quickly?
Thanks for this!
~ Hurley
ingrid
Old 11-19-2005, 11:15 PM   #9
1967 24' Tradewind
Images: 38
he he
No you haven't...but I'm glad to be of help, it's nice to know someone else has the same questions that I do!
Ever forward...
~ Hurley
ingrid
Old 11-20-2005, 05:48 AM   #10
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Thanks for this!
Ingrid,
Canoe stream pretty well covered it. FWIW the factory has switched over to Sikaflex from Vulkem. I still use the vulkem because that is what I have and can readily get. There are different grades of both, but the Vulkem is a slow cure caulk. IIRC both are available from the Airstream Company online store.
Aaron
Old 11-20-2005, 06:58 AM   #11
I had seams at the Argosy's front windows that needed to be dug out. I've got another seam between the door frame and the underlying skin that seems to leak. A knife blade wasn't working well for me. Talk to your dentist and ask about worn out instruments -- sickle scalers don't wear out... darn. Try asking about periodontal curettes and expect to break a tip now and then; their hygienist probably already broke a tip on the other end of these double-ended instruments if they felt inclined to 'donate' it to your project.
Now the secret for fine work -- Search http://images.google.com/ on keywords: Monoject 412 -- you will get some nonprofessional sources for a disposable plastic syringe with about a 1/16" opening at the tip. That's a bit narrow for Sikaflex but can be trimmed back slightly to increase the opening. I haven't found an easy way to clean it for re-use, but it will be good for a few days if you do the freezer trick with it.
Old 11-20-2005, 07:19 AM   #12
I tried other application ideas also. We have so-called fleet stores that have work clothes and general merchandise for farms & ranches. There are a variety of syringe products in the vet supplies area. Check that out if you like. The needles are too small bore and the syringes with needle off is almost too large bore. Dunno...
Old 11-20-2005, 08:18 AM   #13
One Sikaflex source
Okay, I'm going to have to ask the moderators not to give me credit for each of these posts...
Member markdoane was first to mention Austin Hardware if I recall. Their service was very good with internet-only contact. I note that it is still $5.47 a tube. Get the grey -- it is light in color and a good match whether working with an Argosy or Airstream. Link: http://www.austinhardware.com/default.asp?
Old 11-29-2005, 05:32 AM   #14
1967 24' Tradewind
Images: 38
Awesome. Thanks for all this, canoe stream! This one's a print-er out-er.
One more question: which one is the better to get, the Sikaflex 221 or 252, as shown at the austin hardware online store, for my purposes? Does it matter? The 221 is mentioned below, but there always seems to be another factor thrown in for confusion's sake.
~ Hurley
ingrid
Old 11-29-2005, 05:42 AM   #15
The Sikaflex-221 is what I've read Airstream, Inland Andy and others say is the right stuff for our application.
BTW -- I said the Monoject irrigation syringe can't be re-used. That is only after the material sets. I can refill it many times in one work session.
Old 11-29-2005, 04:01 PM   #16
1967 24' Tradewind
Images: 38
got it. Off to shop for squirty stuff!
~ Hurley
ingrid
Window latch dilemma maxandgeorgia Windows & Screens 5 05-18-2018 10:35 AM
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
