Old 08-26-2012, 09:28 AM   #15
Ssp63
2007 19' International CCD
agawam , Massachusetts
sorry i wasnt so clear about things, i removed the dinette ,fresh water tank and pulled the linoleum back far enough to see where the dampness ends thankfully it stops before the fridge and opposing sink
steve powers is offline   Reply With Quote
Old 08-30-2012, 02:24 PM   #16
Mrs.Mod's Avatar
1977 31' Sovereign
Fresno , California
Hi all,
We are getting ready to reseal our AS. We have a 31'. I know it depends on how generously I use it, but how many tubes of TempPro should I get? Mr. Mod thought 3 but I think that doesn't sound like enough.
Also, I'm really horrible at using the thread search,(I'm sure it's just me) but if anyone can point me to a thread that has good tips or info about resealing, I'd appreciate it.
We are both pretty handy, I just want to know about any 'no-no's' before we start.
Thanks!
Cheers,
Cara, John & Johnny
Jet, Our silver stow-a-way
1977 31' Sovereign "The Mod Pod"
2006 Ford F-250 Super Duty
Mrs.Mod is offline   Reply With Quote
Old 08-30-2012, 03:55 PM   #17
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
#1) Must be applied to a clean surface. My favorite outside seam & flange cleaning tool is a nickle-sized 1/16"-wide stainless steel brush wheel on a dremel style rotary tool - patiently clean the old caulk dregs, oxidation, and petrified tree sap and pollen out down to bare bright metal and then apply your educated choice of caulks...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 08-30-2012, 04:03 PM   #18
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
If you are finding damp spots on the plywood subfloor, check the awning support brackets—they do not mate well to the side of the body and easily can leak inside. They should be sealed underneath, on the sides and at the screws. There are 4 mounting brackets for the awning supports—two high and two low.
You can also use aluminum colored Acryl-r to seal on the trailer sides. They have an applicator that puts out a fairly narrow bead.
Gene
