Old 05-13-2017, 01:51 PM   #1
1973 31' Sovereign
Screen door latch rivet broken
How do I get into this latch to rivet in back in? I can't figure out how it comes apart but know it must.Click image for larger version
ID:	285449Click image for larger version
ID:	285450Click image for larger version
ID:	285451Click image for larger version
AustinAir is offline   Reply With Quote
Old 05-13-2017, 03:01 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Not sure but could it have been riveted from the inside before the door was assembled?
2004 Excursion 4x4
Old 05-13-2017, 03:03 PM   #3
1973 31' Sovereign
I hope not then I am boned lol
Old 05-13-2017, 03:08 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
They are a puzzle. It comes apart if you push the slider hard enough. Only problem is I don't remember in which direction. When you finally get the bugger open the little spring likes to go flying and you have a good chance of breaking the 45 year old plastic. They also are not fond of going back together but I have successfully done it. They are no longer available. Inland RV sells a replacement which is aluminum and plastic and larger.
Old 05-13-2017, 03:15 PM   #5
1973 31' Sovereign
Thx I will attempt to repair and order new one⛺️
Old 05-13-2017, 03:51 PM   #6
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
I wrote a blog post on this exact issue (with pictures) here: http://thegreatleys.com/journal/2016...stream-latches
TheGreatleys is offline   Reply With Quote
Old 05-13-2017, 04:29 PM   #7
1973 31' Sovereign
Awesome just the info I needed u rock!
Old 12-19-2018, 09:23 AM   #8
Still Dreaming
Manning G's Avatar
1971 29' Ambassador
Sulphur Springs , Texas
Good info. HOWEVER, make sure you put a rag or something over it while your prying it apart. On mine the slide sprung 10 feet one way and the spring at least the same the other. Never found the spring!
Manning G is offline   Reply With Quote
Convert vintage door latch to modern double rotary latch & strike? Mixter Doors & Locks 5 02-19-2017 09:12 AM
'74 Sovereign screen door / door latch? texasbound General Repair Forum 2 09-23-2012 05:48 AM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 09:52 AM
Screen latch broken gnored Doors & Locks 3 06-12-2009 11:20 AM
Screen door latch broken redeagle313 Doors & Locks 5 04-20-2009 05:03 AM
