Old 06-03-2016, 10:25 PM   #1
1995 21' Sovereign
Castle Rock , Colorado
Rock Guard Window. Wanted. Sovereign 21'
I have a broken Window Rock Guard. This is the one piece unit. 1995 Sovereign 21' The frame is in good shape , The Lexan? is cracked top to bottom R side. There is a total unit at http://odmrv.com/catalog/index.php?m...roducts_id=191 It is $375 and $145 shipping . I live in Denver and wonder if there is anything local I can get?
Tom
tjansen is offline   Reply With Quote
Old 06-24-2016, 11:23 AM   #2
teamhaney's Avatar
1973 25' Tradewind
Omaha , Nebraska
Is it repairable?
Can you source a piece of Lexan locally and put it in the frame you have? A piece that size would run about $100.
teamhaney is offline   Reply With Quote
Old 06-25-2016, 10:39 AM   #3
1995 21' Sovereign
I will look locally. The existing window cover goes edge to edge and covers the wrap side window. Does Lexan bend ? easily? or does it need heat ? From what little I have used Lexan it is TOUGH and does not lend to bending. Thanks for your input teamhaney.
Old 06-27-2016, 08:14 AM   #4
teamhaney's Avatar
1973 25' Tradewind
Omaha , Nebraska
I've read you need to carefully heat both sides of Lexan to bend it. Heat gun works best. Propane torch would too but not as controllable. Leave the protective coat on while heating. Experiment on a scrap piece first.
sovereign
28 FC front window rock guard front center window dayner Windows, Doors, Locks & Vents 0 08-29-2015 06:41 PM
Rock Guard Solar Standard Front window guard ChrisseasCC Windows, Doors, Locks & Vents 1 07-31-2014 07:32 AM
Window Rock Guard balrgn Rock Guards, Segment & Window Protectors 6 10-30-2004 04:00 AM
window rock guard art Rock Guards, Segment & Window Protectors 0 01-13-2003 04:58 PM
