Old 04-13-2018, 01:28 AM   #1
Pride&Joy's Avatar
2001 30' Limited
Terre Haute , Indiana
Rock Guard rubber gasket replacement
Hello fellow Streamers! Our center rock guard on our 2001 Limited has become damaged on 1 side causing the guard to not close easily. The rubber seal has been folded so that the hinge will not lie flat to allow the latch draw to close without really stretching the rubber latch. I've purchased new gasket & can see how it goes on the the edge of the rock guard "track". Has anyone removed this gasket and replaced? It seems to be strongly affixed. Any tips on removal? Is it completely necessary to remove the entire center rock guard to do this? The hinges are fastened to the trailer with rivets so removing looks difficult.
Thank you for any insight on this project!! Attached pics of this center rock guard gasket in place and the replacement seal.
Name:	Rock Guard Seal.jpg
ID:	308600   Click image for larger version
Name:	Rock Guard Pic.jpg
Pride&Joy is offline   Reply With Quote
Old 05-01-2018, 08:58 AM   #2
Depends :) , My heart is in Colorado
I, too, have this same question. Anyone have advice?
Jump, and the net will appear.
Papatango is offline   Reply With Quote
Old 05-02-2018, 03:27 PM   #3
Pride&Joy's Avatar
2001 30' Limited
Rubber Gasket
Since I haven't gotten any advice I'm going to work on this project soon. I'm hoping I can remove the center window and remove the old gasket using adhesive remover and adhere the new one with gasket adhesive. We replaced the window seal this way. The hardest part was removing the old! Thanks for adding to the post, maybe a fellow Stream'er who has some tips on this project will chime in soon!
Rock guard fixed itself. We bought new RS rock guard, waiting for delivery, went to Garymaya Rock Guards, Segment & Window Protectors 1 09-20-2017 03:00 PM
Rock Guard Gasket on 1964 Overlander ljaecks Windows, Doors, Locks & Vents 3 08-14-2014 01:31 PM
Rock Guard Solar Standard Front window guard ChrisseasCC Windows, Doors, Locks & Vents 1 07-31-2014 07:32 AM
Valterra rubber gasket bwaysteve Waste Systems, Tanks & Totes 1 10-13-2010 07:49 PM
Front window rock guard rubber... are they seals? Gator113 Windows & Screens 7 05-30-2010 02:52 PM
