Old 08-13-2014, 12:46 AM   #1
ljaecks's Avatar
1962 22' Safari
1964 26' Overlander
1965 26' Overlander
Wenatchee , Washington
Rock Guard Gasket on 1964 Overlander
The rock guard in our 64 Overlander is not attached to the body. There's a thin slot above the window frame and a thin slot along the top edge of the rock guard. In each slot there's a long round piece of black plastic/rubber tubing that slides out. It appears the two pieces of tubing may have been connected at one time by a thin sheet of black rubber serving as a hinge. Does that sound familiar to anyone?
If so, is there a replacement part available? If not, how do I attach the top of the rock guard to the body?
Any advice is appreciated!
Laura
ljaecks is offline   Reply With Quote
Old 08-13-2014, 06:15 AM   #2
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
On our '66 Safari, the rock guard is held at the top by a full-length strip of piano hinge. Don't know how they did it in '64, but you might consider the hinge as a modification.
Old 08-14-2014, 11:50 AM   #3
ljaecks's Avatar
1962 22' Safari
1964 26' Overlander
1965 26' Overlander
Thanks!
That's a great thought. :-)
Old 08-14-2014, 01:31 PM   #4
1966 22' Safari
Sorry I don't have any pictures, and the trailer is in storage right now so I can't get any right away.
Basically, there is a piece of aluminum angle riveted to the trailer above the front window. One side of the hinge is riveted to that angle, and the other side to the top of the rock guard.
Hope it works for you.
1964, 1964 overlander
'64 Overlander Rock Guard Repair 64Overlander Rock Guards, Segment & Window Protectors 8 06-12-2015 02:59 PM
Rock Guard Solar Standard Front window guard ChrisseasCC Windows, Doors, Locks & Vents 1 07-31-2014 07:32 AM
Rock guard 1967 Overlander Fishbone 1965 - 1969 Overlander 3 11-09-2008 10:15 PM
Window Guard Gasket Position pyanke Rock Guards, Segment & Window Protectors 4 07-23-2008 12:19 PM
Rock Guard for 76 Overlander 2toomany Rock Guards, Segment & Window Protectors 3 02-22-2006 06:28 PM
