Old 10-06-2016, 07:37 AM   #1
1965 17' Caravel
Boerne , Texas
Retaining strip or glazing bead for windows 1965 Caravel
I am new to the Forum and in the process of restoring a 1965 Caravel. I am having trouble finding the above mentioned material. Exterior strip on the windows. The current material is grey in color, flexiable and the Plastic Hall-Mark 12 glazing strip does not work. All the windows are the original HEHR numbers C129901399221185, 511221431, 397221291, 394221395. Any help would be appreciated. Thank you
Texasred is offline   Reply With Quote
Old 10-06-2016, 08:05 AM   #2
Al Boondy's Avatar
1973 31' Excella 500
Vicksburg , Mississippi
Have you tried Vintage Trailer Supply?
http://www.vintagetrailersupply.com/category-s/26.htm
Al Boondy is offline   Reply With Quote
Old 10-07-2016, 06:47 AM   #3
1965 17' Caravel
Boerne , Texas
Window exterior retaining strip
Yes i have contacted Vintage Trailer Supply and they have no solution. Apparently AS used this product from 60-65 only. It appears supplies have discontinued making it. So far i have run into a road block--looks like I will have to retrofit.
Old 10-07-2016, 10:27 AM   #4
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Check McMaster Carr. They may have some thing that may work.
Dingo Girl is offline   Reply With Quote
Old 10-19-2016, 08:27 AM   #5
Goliad , Texas
I am restoring a 65 Overlander with Hehr Mark 12 window frames. I just ordered this material from VT and it is working fine.
You have to have a roller tool and have the frame perfectly clean to install it but it DOES work. The PO decided to use Vulcum to hold the windows in and and it is taking hours to clean each frame and there are 12 windows we are restoring on the '65.
Good luck.
The Frommes
Goliad, Texas
The Birth Place of S. Texas Ranching
WBCCI #6256
eartick is offline   Reply With Quote
Old 10-19-2016, 10:45 AM   #6
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I used it on my 1964 Bambi II, which has pretty much the same windows as your 1965 Caravel...Click image for larger version
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
1965, caravel
How the heck do you remove the round retaining clips to remove the windows?? bvcg1 Windows, Doors, Locks & Vents 2 08-30-2015 01:57 PM
new window glazing strip shrinking 63air Windows & Screens 10 10-20-2008 08:09 PM
Hehr glazing strip...45 degree or? Zstream Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 06-02-2008 10:27 AM
Trouble with replacement glazing strip Jacob D. Windows & Screens 5 11-09-2006 02:32 PM
need window glazing bead for '63 Globetrotter 63air Windows & Screens 2 10-14-2004 09:31 AM
