Old 01-12-2016, 03:16 PM   #1
1971 31' Sovereign
Temple , Texas
Restoring window support rods
Before removing the windows on my 1971 Sovereign to refurbish them I had to remove the support rods. I found the easiest way to remove the clips that hold the rods in place was to use a cut-off wheel in my Dremel. I just cut off part of the clip and used a hammer and screw driver to pop the clip off. Took about 20 minutes to remove all 8 windows.
Anyway...the support rods looked pretty bad after 45 years. I cleaned them up with a 1" belt sander from Harbor Freight using a cloth belt. As you can see from the before and after photo, this technique worked well.
I think paying attention to the small details like this is important IMHO.
TxDave is offline   Reply With Quote
Old 01-12-2016, 03:32 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Spray some Nyalic on it to keep it sparkly!
Peace and Blessings..
Channing
WBCCI# 30676
Old 01-12-2016, 05:20 PM   #3
1971 31' Sovereign
Temple , Texas
Thanks, cwf. First I ever heard about the stuff (Nyalic). Did a google search...looks like something that would definitely be beneficial.
Old 01-12-2016, 09:55 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Dave,
I have a can I used to repair bad spots on our AS. Have some left if you want to test out. Of course, having the "system" they offer will give best results.
The areas I have treated have been great for over a year. No need to wax, polish, just great product!
Channing
WBCCI# 30676
Old 01-13-2016, 03:06 PM   #5
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
I'm curious how much luck you have reinstalling the clips. Ive had several that just don't stay on long term. I get them on and all seems good then after using awhile they seem to pop off!
rucos is offline   Reply With Quote
Old 01-13-2016, 11:15 PM   #6
1971 31' Sovereign
Temple , Texas
I'll let you know how that works out, rucos.
Old 01-18-2016, 02:29 PM   #7
1969 27' Overlander
Wimberley , Texas
Thanks for the post, where do you get new clips?
curtisjinkin is offline   Reply With Quote
Old 01-18-2016, 09:44 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If using "E" clips, and they fall off, usually you are using an incorrect one.
Better yet, try a "retaining clip".... McMaster-Carr
Here is a link.. Look around.. May be available at auto supply!
Channing
WBCCI# 30676
Old 01-19-2016, 09:03 AM   #9
1969 27' Overlander
Wimberley , Texas
Thanks for the link! Very helpful
Oh No! - no curtain rods Doogie521 Upholstery, Blinds, Walls & Interior Finishes 1 06-09-2008 06:41 PM
Deal on Backup Guide rods. $9.99 Jim Clark Hitches, Couplers & Balls 4 11-27-2007 08:36 PM
Need replacement curtain rods '77 Argosy Tim Can Upholstery, Blinds, Walls & Interior Finishes 0 06-08-2007 12:41 AM
Tabs or Rods 63 GT hantri General Interior Topics 5 02-14-2007 07:59 PM
Curtain "rods" ~ c- channel ??? CaddyGrn Upholstery, Blinds, Walls & Interior Finishes 9 06-26-2006 11:28 PM
