Old 06-22-2012, 09:20 AM   #1
1976 31' Sovereign
Alexandria , Louisiana
Replacement Glass
Have 1976 Sovereign with a shattered curb side bedroom window, 30" curved type, can you buy just the glass? Anyone know where to order if so? Thanks
mhebert1256 is offline   Reply With Quote
Old 06-22-2012, 09:31 AM   #2
See your other post.
Glass "ONLY" has never and will never be available by itself.
Next issue is Airstream will not sell the gray gasket.
After that, you will have much trouble getting the two halfs of the sash apart, and that's after you drill out the hinge rivets.
Then, you will find that getting the 2 halfs back together again, "properly", becomes an almost impossible task.
Of course now you have to rivet the hinge back in place, as well as replace the black exterior gasket.
Then you will learn, that the hinge has now developed something other than a straight shape, making the reinstallation a real bummer.
You can however purchase the "glass and sash".
Glass shops don't have tempered curved glass available.
If you like pain, go for it.
Old 06-22-2012, 09:34 AM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Call Inland Rv in California. they might have it Inland RV Center - The Nations Leading Expert in Airstream Innovations
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-22-2012, 10:02 AM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
You can order this part from your local Airstream dealer. No need to pay the extra shipping. Windows are not cheap, but a necessity. You might be able to buy a used one from the Airstream bone yard in Nebraska.
