Join Airstream Forums Today
Old 12-19-2011, 02:44 PM   #1
Houston , Texas
Replacement Door for 1977 23' Safari
I am considering purchasing a 1977 Airstream Land Yacht Safari that's in overall good shape; however, the main access door must be replaced. IAny suggestions on where to purchase a replacement door/frame? How much might I expect to pay? Comments/suggestions appreciated
KittyTexas is offline   Reply With Quote
Old 12-19-2011, 03:18 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1998 30' Limited
1947 22' Liner
Valley View , Texas
Images: 47
If the door needs replacement..How come?....probably needs hinges and may have a broken cast frame. This could be a very expensive proposition.
Old 12-19-2011, 03:23 PM   #3
New mian doors are available through a dealer.
They cost a little more than $2000.00, plus shipping.
Cast frames were last used in 1973 models.
Main doors can usually be rebuilt, at least by someone that has done exactly that before, which will insure a proper fit.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 12-19-2011, 04:21 PM   #4
Houston , Texas
Many thanks!
[IMG] code is Off
1971 Safari Axle Replacement pickerdd Axles 22 02-25-2012 03:57 PM
Safari :: 1996 Airstream Safari Land Yacht tlw12 Airstream Registry Discussions 0 12-18-2011 08:47 AM
Safari Step Replacement Photo Guide TinLoaf Steps 5 09-09-2011 06:17 AM
Replacement tires for 2006 Safari 23 Goal15 Tires 0 05-16-2011 12:45 PM
