Old 06-02-2014, 11:00 PM   #1
1970 27' Overlander
1989 32' Excella
Bay City , Texas
replace or repair window
front window on recently purchased 1989 32' excella was broken. Can most glass repair places fix this or does it require replacing with new window? Where would I go to find one? Any help appreciated. Ken
capt ken is offline   Reply With Quote
Old 06-02-2014, 11:44 PM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
How broken? The BETTER glass repair shops can repair a long single crack (I've seen a 12 inch one that was done), but if you've got a spiderweb it pretty much has to be replaced.
Paula
Old 06-03-2014, 03:33 AM   #3
Taking the window frame apart, is not as easy as it seems.
There are steel angles in each corner. In time, they rust which usually seizes them to the aluminum. Trying to pull the aluminum apart then, usually causes them to bend out of shape.
Old 06-03-2014, 11:17 AM   #4
1970 27' Overlander
1989 32' Excella
Bay City , Texas
Thanks Andy, so it looks like a complete window, where can I find it?
Old 06-03-2014, 05:52 PM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I believe that one is new enough that most Airstream Dealers can get one for you from Airstream.
Aaron
WBCCI #XXXX AIR #2495
To Replace or Not to Replace 65air Towing, Tow Vehicles & Hitches 3 03-29-2013 12:58 PM
2 replace decal or not to replace? nustreamer Clearcoat, Exterior Paint & Trim 1 07-15-2011 10:28 PM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 06:20 AM
window leak/repair/replace? gwendolyn Windows & Screens 1 01-22-2006 10:09 AM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
