Old 03-04-2012, 04:00 PM   #1
1961 22' Safari
Sarasota , Florida
Removing Windows in '61 Safari
My 61 Safari has an aluminum flashing over the windows that is riveted onto the body. Do I have to remove these flashings in order to remove
the windows, i.e. slide them out of their tracks?
Also missing one window, it measures 21" wide by 17-1/2 high. It is the
window over the sink. If anyone knows where I could find one I'd be
most grateful.
dprmcr is offline   Reply With Quote
Old 03-04-2012, 04:06 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
You should be able to remove the single philips screw keeping the window frame in the track, and slide the window out after removing the lift arm. You may have to persuade the frame to start moving. Good luck with the window, I finally found one that was too big, and am going to have to cut it down and weld it to fit.
Old 03-12-2012, 09:33 AM   #3
1961 22' Safari
Sarasota , Florida
Thanks Terry for the tip.
Haven't attemped yet, but getting closer.
Old 03-12-2012, 09:42 AM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
You may have to remove one or 2 rivets to spring the eyebrow out of the way enough to slide the window clear. I have seen some with a screw at one end, probably for this reason.
I had to remove all the eyebrows on my 61 and reseal them anyway, so this might be an opportunity to do that one
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 03-12-2012, 11:57 AM   #5
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
I have to remove a window on my '64 Bambi II and I know exactly what you are talking about. All I did was bend the eyebrow up slightly, just enough to get a screwdriver in to loosen the set screw. Once my broken corner is welded and the window put back together, I will slide the frame in, replace the set screw, and bend the eyebrow back into position.
Hopefully this process will not leave too noticeable a crease in the thin eyebrow metal.
Ben
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Replacing windows in 1967 Overlander MAbdala Windows & Screens 12 05-15-2015 05:46 PM
Our '56 Safari (aka Our Retirement Home) SafariSteve 1956 Safari 41 09-04-2013 05:55 PM
Removing window frames '61 GT streamahead Windows, Doors, Locks & Vents 3 07-30-2011 09:47 AM
Removing International Furnace from 1965 Safari miscwires Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-17-2011 05:10 AM
