Join Airstream Forums Today
Old 07-30-2011, 07:50 AM   #1
1962 19' Globetrotter
1956 22' Flying Cloud
1968 17' Caravel
Murray , Utah
Removing window frames 61 GT
With the interior gutted in my 6/61 GT, im now looking at those crusty windows and frames. Ive read a good deal about removing the windows, but haven't found any threads on removing the frames? Looks like they would come out in two pieces (inner and outter), after removing the bucked rivets? Im considering removing the frames mainly for the ease of polishing and re-sealing. Is this a bad idea? It looks like the sealing gasket is pinched under the frame all the way around? Anyone done this on a similar year AS? Any advice before I begin would be appreciated. I will definitely order the replacement seals etc, before I begin. Im getting closer to being ready for paint inside, im thinking it would be the right time to paint with window frames out.. any insight with this in mind would help too.. Thanks.
Jason
streamahead is offline   Reply With Quote
Old 07-30-2011, 07:55 AM   #2
touched
62overlander's Avatar
1948 22' Liner
Catonsville , Maryland
The window frame will come off in one piece from the outside, just drill or shear the rivets. I think it a very good idea, for when installed again you can be sure the new sealant will not leak. You need to buck rivet them back on. The inside frame is four pieces of bent aluminum. I usually make new ones as to not waste labor stripping the old ones. Hope this helps.
Frank Yensan The Airstreamer's Club USA-1 "we're dead serious about having fun"
http://annalumanum.blogspot.com/http://frankstrailerworksblog.blogspot.com/
www.frankstrailerworks.com
62overlander is offline   Reply With Quote
Old 07-30-2011, 07:57 AM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Take a look here...Restoration Topics - Window Repairs
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 07-30-2011, 09:47 AM   #4
1968 17' Caravel
Murray , Utah
Thanks guys.. I looked at the link to window re-seal.. that will be helpful. So, the exterior frame is buck riveted to the 4 piece inner frame, correct? I understand what youre saying about building new ones, but in my case, cleaning up the originals would be best. How prudent is it that I buck them when re-installing? It would seem that pop riveting and adhesive would be sufficient? Im just getting deeper and deeper here.. and I have concluded that I will pull the frames.. Would it be a mistake to do it after painting the interior walls around the frames? It would be nice to tackle the window frames when I get to the exterior, whats your thoughts on that?
Jason
[IMG] code is Off
R & R Argosy wrap window Michael W Windows & Screens 4 09-09-2011 07:42 AM
Removing inner window pane GaCamper Windows & Screens 4 05-15-2011 06:06 PM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
1963 Sovereign Window Frames Needed Kim-n-Mark Windows & Screens 0 03-26-2011 04:00 PM
1972 Trade Wind.. interior aluminum window sceen frames Janie Q General Interior Topics 3 03-25-2011 05:20 PM
