Old 02-28-2012, 10:23 AM   #1
Mooresville , North Carolina
Removing window entirely
I am modifying my 1974 Sovereign and want to remove some of the windows as I will need the wall space more. Does anyone know what I can replace the glass with that is black from the outside or can be painted black to still look like a window?
jtsanchez is offline   Reply With Quote
Old 02-28-2012, 10:43 AM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
Consider fabricating an aluminum plate to replace the existing window; this won't break and is completely reversible if you change your mind later on.
You can remove the top hinge plate from the glass window and use it on your solid aluminum one. If this window is gently curved, a sheet metal shop can help.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 02-28-2012, 10:45 AM   #3
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Seems like you could leave the windows intact, and just replace the interior screen with a sheet of aluminum or whatever you wanted. If you wanted it to look black from the outside, slip something black inbetween the glass and (former) screen. I'd be leery of permanently removing ANY windows, because of the work involved and possible loss of re-sale value down the road....just my 2 pesos worth.
tphan is offline   Reply With Quote
Old 02-28-2012, 10:55 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Adding a dark tint (film) to the window and installing a panel on the interior would be an easy way to do this.
Richard
Old 02-28-2012, 11:31 AM   #5
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Why not paint the inside of the glass black and replace the inside screen with a sheet of aluminum?
Cheap, easy and reversible.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 02-28-2012, 02:25 PM   #6
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Another option might be to leave the window as it is, and replace the inside screen with a sheet of aluminum painted black on the side facing the window.
Even easier.
Old 02-28-2012, 04:07 PM   #7
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Check out this thread post 61
http://www.airforums.com/forums/f183...x-23481-5.html
Old 02-28-2012, 06:21 PM   #8
Thanks all. I think I'll do a limo tint to the inside, insulate and then wall off the window. This should be the least amount of modification and least amount of my time.
Old 02-28-2012, 06:39 PM   #9
1974 Argosy 20
Kooskia , Idaho
Make sure you put new gaskets on the window prior to walling it off as you will not be able to get to them in the future.
Vista View Window Questions CBWELL Windows & Screens 15 07-07-2012 08:36 PM
Broken window - how to replace? MyParadise 2002 - 2005 International 0 02-27-2012 11:22 AM
Window sash removal lowellgray Windows & Screens 2 02-24-2012 09:37 AM
