Old 12-10-2009, 01:03 PM   #1
1969 21' Globetrotter
Santa Rosa Beach , Florida
Rear Rockguard?
At out of doors mart, I have already settled on getting the front rockguard for my 69 globetrotter, but what about the rear? Does it have a rock guard set anywhere online? I can't seem to find one.
THanks,
-Sean
Igobarefoot is offline   Reply With Quote
Old 12-10-2009, 01:25 PM   #2
Kevin245's Avatar
I'm not aware of any being commercially available. The intent of a rockguard is to provide protection to the glass area during the course of travel, and shading while camped. So having one for the frontal windows is important.
I believe your front wing windows have the double square corners that are virtually extinct so you should definitely protect them.
I have seen some owner's with homemade ones used on rear windows but most people use a window awning for that purpose. Plus the rear window is often times your "Escape Window" so having it covered by a rockguard could be a problem in case of an emergency.
Regards,
Kevin
Eleanor Roosevelt
Kevin245 is online now   Reply With Quote
Old 12-10-2009, 01:41 PM   #3
THanks,
-Sean
Using a front rockguard, that covers 3 windows, for a single rear window, is a waste of money.
You can, however, use for the rear window, the same rockguard that is used for the single front window models, such as 68 and older.
Plus, it's cheaper, costs less to ship, and is easier to install.
Instead of being 80 inches wide, the single window version, is only 47 inches wide.
Old 12-10-2009, 01:50 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
I'm pretty good at backing up but would probably jackknife before reaching a speed at which I'd need a rear rockguard for the panoramic windows on the back of my SE Safari.
The metal shields for the lower front corners are called segment protectors. I don't think you'd need those on the rear either.
5 meter Langford Nahanni
Old 12-10-2009, 10:08 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, a rear rock guard might come in handy if you have rock throwing kids or kids with BB guns and the rear of your trailer is exposed. O.P. might have a similar reason for wanting one.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Replacement Parts for Rockguard? tslanier Windows & Screens 2 07-15-2006 07:38 PM
Rockguard Repair on '93 Sovereign. jhart657 Rock Guards, Segment & Window Protectors 2 09-30-2004 09:37 PM
fabricating a rockguard for a 67 TW JimC Rock Guards, Segment & Window Protectors 2 10-14-2003 06:24 PM
Rockguard tmeagle1 Rock Guards, Segment & Window Protectors 12 04-02-2003 07:59 AM
New rockguard installation davespann Rock Guards, Segment & Window Protectors 0 03-02-2003 06:16 AM
