front window glass/plexiglass gasketing
Let me rephrase the question with more info.
We have cleaned the plexiglass and the glass panes and frames.
Recall the "D" gasket that you normally glue around the aluminum frame of the other windows.
I was considering attaching one continuous strip of the "D" gasket to the inside of the plexiglass frame with its normal adhesive. That way I only have one joint, each end of the gasket, to use the 3M adhesive to make the seal. When you install the plexiglass frame it pushes the curved side of the "D" against the glass.
The questions are:
Has anyone done this before?
Did it or did it not seal properly?
What are other alternatives that others have done?
