Join Airstream Forums Today
Old 10-30-2011, 04:00 PM   #1
1974 27' Overlander
Sammamish , Washington
Plastic window pull guides
I need to replace the white plastic window pull guides (that attach to the side of the window frames to hold the windows open. I have the replacement guides (in black). Question: What is the proper size rivet to install the new plastic guides? I assume the rivet is 1/8", but what is the proper length?
Chuck Neir is offline   Reply With Quote
Old 10-30-2011, 06:48 PM   #2
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
1/8" dia. with 1" grip. Put in the top and bottom rivets first and drill the middle holes if they don't line up.
Flynavy is offline   Reply With Quote
Old 10-30-2011, 10:07 PM   #3
#45 or #48 pop rivets will work fine.
#45 has a grip range of 5/16" and #48 has a grip range of 1/2 inch.
I don't know where you would find a 1/8 inch pop rivet with a 1 inch grip range.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 10-31-2011, 05:11 AM   #4
Well Preserved
overlander63's Avatar
Colfax , North Carolina
#46 rivets are more than enough, which is about 1/8"x3/8".
Some days, it's just not worth chewing through the restraints.
Old 11-01-2011, 08:23 PM   #5
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
Opps!!! You guys are right. Having a CRS attack again.
[IMG] code is Off
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 13 01-05-2012 06:41 PM
Plastic Window Knobs or Crank boutdoors Windows & Screens 0 05-09-2011 04:08 PM
Rear window leak fixed! Really? I think so. GlobeTrottin 1964 Globetrotter 0 04-30-2011 05:42 AM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
'58 Hehr Window - Is this the correct window operator replacement? mello mike Windows & Screens 13 03-25-2011 08:31 PM
