Old 10-06-2012, 06:31 AM   #1
dclampe's Avatar
1965 26' Overlander
Avon , Indiana
Pesky window screw
I'm replacing windows in my 65 overlander and there's a screw in the top channel right under the gutter that needs to be backed out before the window can slide out. The first one I did I bent the gutter up and got the screw out and was able to bend the gutter back into place without too much trouble, but I'm searching for a better way. I'm guessing the only other way would be to remove the gutter? What have others done?
Also, the screw appears to be steel. Does anyone have a source for a stainless replacement?
dclampe is offline   Reply With Quote
Old 10-06-2012, 07:02 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Needle nosed vise grips clamped on the screw head may work.
Sometimes a really short screwdriver bit like used in drills can be used as a right angle screwdriver by putting a 1/4 inch box wrench on it
Sources of stainless screws can be found on the net but I don't have the info handy right now
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 10-06-2012, 07:31 AM   #3
StPierre's Avatar
1965 22' Safari
Rescue , California
I just finished all the windows in my 65 Safari , and I had to bend the gutter up and used neddle nosed vice grips as Rick stated. I found that was the best way
The St Pierre's
StPierre is offline   Reply With Quote
Old 10-06-2012, 08:00 AM   #4
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Originally Posted by dclampe
... Does anyone have a source for a stainless replacement?
Have you checked with Lowe's or Home Depot? They have a fastener aisle that has a variety of screws and bolts packed in small quantities, I've seen some stainless choices the last time I was looking. Also check the yellow pages under fasteners to see if there is a retail distributor nearby. They usually sell by the box.
AIR 47751
Silver Goose is offline   Reply With Quote
Old 10-06-2012, 08:18 AM   #5
airstream4's Avatar
1997 34' Limited
1963 22' Safari
Troy , Michigan
I have used vise grips with some success and a grinder and drill another time. I use McMaster Carr for stainless screws. I was afraid of bending the gutter, thought i might destroy!
Good Luck
Paul
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
airstream4 is offline   Reply With Quote
Old 10-06-2012, 06:55 PM   #6
dclampe's Avatar
1965 26' Overlander
Avon , Indiana
Thanks for the suggestions. I'll give it a shot the next few days.
Old 12-02-2012, 12:56 PM   #7
awolff's Avatar
1966 17' Caravel
Roseville , California
If you have an Ace Hardware or True Value, they usually have stainless screws.
awolff is offline   Reply With Quote
