Old 09-08-2015, 08:49 PM   #1
ALí UM- MONEY's Avatar
1976 31' Sovereign
Ball Ground , Georgia
One more vista view question
I have resisted removing the inner pane of my vista view from my 1976 mostly due to the thermal pane effect. They are so bad that I keep the shades pulled all the time. Will I lose energy effecency? If I decide to break one pane what do people do with the gap created. I know this has been discussed before but if I do this there is no going back.
A husband is the biggest baby you will have and take the most adult supervision.
Gene and Elaine Thomason
Ball Ground Ga.
1976 31 foot Sovereign
2011 GMC 2500HD Denali
6.6 Duramax Diesel
ALí UM- MONEY is offline   Reply With Quote
Old 09-08-2015, 09:05 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Well, you might try doing a google search from outside the forums and use terms like "vista view airforums." You should get several threads discussing rebuilds.
As far as thermal efficiency, I would guess it will have minimal impact if you remove the inner pane, as the majority of the windows in the trailer are only single paned anyway, plus the whole trailer is composed of highly conductive aluminum skins with an aluminum rib every so far along its length.
I disassembled my vistas, removed the inside pane, and used a piece of black automotive rubber hose to fill the gap and apply some pressure to the outer pane to help keep the seal. So far, so good.
good luck!
Old 09-08-2015, 10:36 PM   #3
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Can-Am can supply a replacement gasket to fill the gap after removing the inner pane. There are various ways the pane is retained (some disassemble, some need to be broken). Take a look at this thread http://www.airforums.com/forums/f454...ws-113847.html
martin300662 is offline   Reply With Quote
Old 09-08-2015, 11:46 PM   #4
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
You will lose energy efficiency especially in cold weather. The single pane is drafty and condensation forms. I keep the covers down on cold nights.
4RXLA is offline   Reply With Quote
Old 09-11-2015, 04:25 PM   #5
art
vista view
I removed the inner glass on my 77 ,I did all 3 and 2 came out fine one broke in the process so be prepared they look great after but it cost a few hundred to get a replacement from airstream .its a little project to drill all rivets out reseal and replace the little bugger but i was happy when done. good luck
art is offline   Reply With Quote
Vista View window repair/replacement 83Excella Windows & Screens 14 06-06-2013 05:38 AM
See more. Do more. Live more...? Mike91208 Airstream Lifestyle 2 01-26-2012 06:56 AM
quick question about Vista View windows funkill Windows & Screens 0 03-27-2009 09:24 AM
Vista View Question Brian W Windows & Screens 3 03-29-2006 12:01 PM
Vista View Windows On 1979 31' Soverign montanaandy Windows & Screens 14 10-17-2002 05:03 PM
