Old 04-26-2016, 10:03 AM   #1
2016 28' Flying Cloud
The Plains , Ohio
Angry nx awning operation
I am trying to follow the directions about opening the patio awning and raising it so that i can open the door. If I get to the last step the tension on the awning is so high I can't pull the pin to raise the awning. If I first raise the awning, I find I'm not tall enough to push the awning up and out to extend the arm so I need to use a ladder which is precarious pushing against the tension on the awning. So what i've done is first raise the awning and then put on the tension arm. If I do that, on one side I can't really extend the tension arm because everything is so tight.
I feel so inadequate
any suggestions?
whitegs is offline   Reply With Quote
Old 04-26-2016, 10:11 AM   #2
any suggestions?
There is "nylon wheel" available that mounts on the top of the door. That eliminates the awning problem.
And it's cheap too.
Old 04-26-2016, 10:18 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
ZD makes assist handles. Check their web site.
MICHAEL
Old 04-27-2016, 07:32 AM   #4
AWCHIEF's Avatar
Images: 33
These might help
http://awningsbyzipdee.com/3801.html
MICHAEL
Dometic refrigerator 12vDC operation walter1 Refrigerators 19 08-28-2013 11:47 PM
Awning operation timmy67 Awnings 17 07-21-2008 02:32 PM
Heat Pump and Furnace Operation Cracker Water Heaters, Filters & Pumps 21 12-10-2003 03:10 PM
Erratic Brake Operation cesurman Brakes & Brake Controllers 14 04-14-2003 09:54 AM
Univolt Operation melprice Electrical - Systems, Generators, Batteries & Solar 11 06-17-2002 04:13 PM
