Old 12-02-2019, 05:52 PM   #1
elatchford's Avatar
1967 26' Overlander
San Jose , California
not THAT Bargman L-100... ('67 main door)
Hi all...
Earlier this year, I got a '67 Overlander, door suicide victim.
I was able to find a salvage main door that was compatible. It was the right shape and fit, and came with its own main hinge. The original '67 hinge was attached with 6 rivets, the salvage hinge had 4 screws set in the hinge casting. Locating it right over the existing hinge outline worked, though.
Great, I have a hung door, on to the handle and lock. I went out on eBay and got a Bargman L-100 lockset- there is a stamp on the inside handle backplate that says L-100-6, and a stamp on the lock mechanism itself that says L-100-4.
When I go to install it, I have a problem. The existing opening on the salvage door is cut from about 3.25 inches to 5.75 inches away from the edge of the door skin. The L-100-4 lockset only sticks out about one inch from the edge of the backplate. Pictures attached, hopefully... what am I missing? Help!
Erich
ID:	357193   Click image for larger version
San Jose, CA
Current Projects:
1904 Craftsman
1959 Triumph TR3a
1967 Airstream Overlander
elatchford is offline   Reply With Quote
Old 12-02-2019, 06:40 PM   #2
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
You will need to purchase a long bolt for the L100 lock, Inland RV has them a little pricey. Hopefully someone on the Forums will have one they will let go.
cole3444 is offline   Reply With Quote
Old 12-02-2019, 07:45 PM   #3
Central , Mississippi
Vintage Trailer Supply also sells the long version. I bought one and shortened it.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Bargman L-100 Pics - need parts JoePfznik Doors & Locks 42 02-12-2018 08:57 AM
bargman l-100 modified door handle karen.dunn Airstream Classifieds 0 04-15-2015 07:01 AM
Door knob: Bargman L-100 or L-200 - 1964? joedombroski 1960 - 1964 Globetrotter 0 07-25-2013 09:09 AM
