Old 09-29-2018, 12:42 PM   #1
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
noisy cabinet door springs
Any ideas about the noisy cabinet door springs? I've tried using spray lubricant but they are very noisy when opening and closing the door.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 09-29-2018, 03:16 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
... ummm.... try a better spray lube?
There are a lot of different products out there for lubricating things. If it really *is* the spring (and not the hinge) you may need something like a white lithium grease spray.
What are you using now?
Old 09-29-2018, 03:18 PM   #3
Portland , Oregon
I'm using tri-flow. It clearly is the spring making the noise.
Old 09-29-2018, 04:01 PM   #4
Half a Rivet Short
Hi
Well, the spring its self should not make any noise at all. The ends of the spring working against the hubs on the arms might make some noise. That's a high pressure junction and why you will need a grease to cure the issue.
Old 09-29-2018, 04:06 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Have you tried...
...loosening the tension 'til it just holds closed enough to keep the stuff in?
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 03-03-2019, 06:43 PM   #6
honi soit qui mal y pense
Robere's Avatar
2015 23' FB Flying Cloud
Bend , Oregon
Having same problem. Wife unhappy. Help!
Two of seven cabinets have noisy springs. They are the most utilized over the galley area on our 2015 Flying Cloud. I have lubricated with silicone spray and adjusted tighter and looser. No change in problem. I know someone must have a resolution. Make my day and help make Jacqueline ecstatic. Thanks in advance.
Robere (aka Pepe) & Jacqueline (aka Gigi)
with pups Ella (the miniature poodle)
and Tibet (the Lhasa Apso)
2016 Chev Silverado LT Crew 4x4
Robere is offline   Reply With Quote
Old 06-08-2019, 10:21 AM   #7
2014 22' FB Sport
Johnsburg , New York
I used some gen purpose lithium grease right where the spring wraps around the plastic bearing. The obnoxious noise went away as the grease worked its way around and under the wrap. My wife was much happier.
2InACan is offline   Reply With Quote
Old 06-08-2019, 11:51 AM   #8
2002 19' Bambi
Lafayette , California
I suspect you have the real solution. As others have mentioned, the spring itself is very unlikely to make the noise, but it certainly will help transmit and amplify sound from vibrations originating at its ends.
Tim
Tim A. is offline   Reply With Quote
Axles: Dexter, Leaf Springs, Coil Springs, Straight Axles Ray Eklund Axles 22 09-10-2016 06:02 PM
Pagosa Springs, CO to Steamboat Springs, CO TBRich On The Road... 15 06-03-2016 02:59 PM
Under-Cabinet Light = Scorched Cabinet! MohawkDaddy General Interior Topics 7 09-24-2015 02:47 PM
SoCal dilemma: Desert Hot Springs, Borrego Springs or Temecula? Stella On The Road... 5 03-13-2011 04:59 PM
flip up cabinet springs:? billiards Cabinets, Counter Tops & Furnishings 4 01-24-2011 06:25 AM
