Old 04-08-2011, 10:49 PM   #1
1971 27' Overlander
Seattle , Washington
NEEDED: Two front windows for '71 Overlander
Help! On our airstream travel across the country, we ran into a pretty big problem. The two front windows in our 71 overlander shattered for reasons we are not sure about. Happened while driving. Wind? Heat? Rocks (although we found none inside) the windows just shattered. We are in need of two front windows for our 1971 overlander. If anyone has any resources, please let me know!
jesse_kevon is offline   Reply With Quote
Old 04-08-2011, 10:55 PM   #2
x
XXXX , XXXX
Inland RV carries them. They are single pane only as the double pane units are no longer available.
Inland RV Center Inc.
wasagachris is offline   Reply With Quote
Old 04-10-2011, 10:06 AM   #3
1971 27' Overlander
I have just decided to replace windows with Lexan. We will see how this goes...
Old 05-30-2015, 09:11 AM   #4
1973 31' Sovereign
saraland , Alabama
front windows wanted
i have 2 front corner windows one good shape the other has water in it seal needs replaced. i will sell them both for $100. it is an ambassador but im pretty sure they will fit i also have other windows if needed.
just2drive is offline   Reply With Quote
Old 05-30-2015, 09:26 AM   #5
1973 31' Sovereign
saraland , Alabama
71 ambassader window
i have 2 front windows from an 71 ambassoder 1 has water in it, needs new seal. I will sell both for $100
A 1963 Overlander named Moonraker! reinergirl 1960 - 1964 Overlander 702 08-28-2017 11:36 AM
Help! My '63 overlander need plumbing, hot water tank, and water supply tank! aprilr 1960 - 1964 Overlander 9 11-30-2011 08:52 AM
Foggy front curved windows adamgraves Windows, Doors, Locks & Vents 3 09-24-2011 07:52 PM
Catarina 1963 Airstream Overlander :: 1963 Airstream Overlander utee94 Airstream Registry Discussions 0 08-19-2011 08:31 AM
Considering a '67 Overlander, Advice Needed hlo Buyer Guidelines 3 06-16-2011 01:56 PM
