Need some help! It looked simple...
Ok I need some help. My objective is to replace the frosted glass on our 25FB FC with clear HD Lexan. I found Lexan that is rated for entrance door use. We also ordered Ocean Air shade to mount above the door, and pull down for privacy at night. Seemed simple, right!! wrong... Or so it seams...
I removed the inside trim, expecting to be able to pry the frosted glass out, but it seems that the frosted glass is wrapped in an aluminum extrusion, that is riveted to the skin. From looking at the construction, it seems that the only way to remove the frosted glass, is to actually remove the rivets from the skin. Is that correct??
If that is what I have to do, I think I will abandon the idea and try and return the Ocean Air shade.
Or is there a way to remove the glass without removing the entire window unit?
Al
