Old 08-06-2017, 04:01 PM   #1
Watertown , Massachusetts
My door slamming solution
Left – Note how the dead bolt sits after being pushed out using the key and note that it rests right at rubber door seal. This causes the dead bolt to hit the frame of the receiver. Right – I can take my finger and push the dead bolt back towards the inside of the trailer. Notice how much “slop” there is in that dead bolt!
Left – I cut a piece of plexiglass (2” x 3/8”) and slipped it in, but not quite all the way, between the dead bolt and the lock frame– it rests up against the rubber door seal, which helps keep it in place. There is also a little hole drilled in the end in case I need to pull it out at some time. (The plexi is clear and hard to see, so I drew it in with blue lines.) Right – where the dead bolt sits after being pushed out using the key. Now the dead bolt hits it’s receiver every time without slamming the door!
sallye is offline   Reply With Quote
Old 08-06-2017, 04:59 PM   #2
1977 Argosy 24
Milltown , Wisconsin
It would be nice if your pictures worked.
ventport is offline   Reply With Quote
Old 08-06-2017, 05:55 PM   #3
What?
I don't know what you mean by "worked".
Old 08-06-2017, 06:03 PM   #4
2018 27' Flying Cloud
GRAEAGLE , California
We can't see your pictures - looks like they did not upload
AirMagic is offline   Reply With Quote
Old 08-06-2017, 06:31 PM   #5
Try again
Trying again:
Picture 1
Picture 2
ID:	291501   Click image for larger version
Old 08-06-2017, 06:43 PM   #6
Reads a lot
Titusville , Florida
Now we can see the photos. Thank you for sharing.
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
Old 08-07-2017, 03:17 PM   #7
2017 30' International
Cumming , Georgia
Had the same problem
I have a 2017 International and I was having a hard time getting my door to close properly. You had to really slam it to get it to fully latch. This was especially hard to do from inside the trailer . Also my dead bolt would not latch. It seemed to be just a little out of alignment such that it would not extend all the way out as it was not lined up with the hole in the door jam . I took my trailer back to my dealer, Southland RV in Atlanta. They were great!
My door latch had a bent plate inside that they replaced off a new AS on their lot. That solved the problem of having to slam the door.
The deadbolt was out of alignment due to how it's made. My technician took my deadbolt mechanism out of the door and showed me what this issue was. The sliding part of the mechanism, the bolt, is held in place by 4 bent tabs that are not bent enough as they come from the factory.
The tech said he sees this a lot and has notified AS. With the deadbolt assembly out of the door you can pound those 4 tabs down a bit more which will keep the bolt over about a quarter inch which allows it to slide into the slot in the door jam. The tech said all you have to do is slam the door with the deadbolt extended once and it will cause it to shift over just enough so it won't line up with the hole when the door is closed. The only way to fix this problem correctly is to remove the deadbolt assembly from the door. Once it's out you will see the problem.
Good luck!
Scott59 is offline   Reply With Quote
Old 08-07-2017, 03:26 PM   #8
Long Island , New York
FWIW I remember reading this on another thread here, which might also be helpful in resolving the problem. I will look for that thread.
sallye, do you remember ever slamming the door with the deadbolt extended out? We have the same 2014 FC20.
Peter
PS -- Here are the search results for "deadbolt adjustment" FYI:
https://www.google.com/search?q=dead...=airforums.com
PS2 -- YouTube videos which might help: https://www.google.com/search?q=yout...utf-8&oe=utf-8
Slamming the hatch? Belbein General Repair Forum 12 04-16-2014 11:35 AM
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 06:07 PM
Door in a door '53 cloud inner door size. Flysoncloud Doors & Locks 13 09-18-2010 07:10 PM
A Sewer Solution.... Solution FreshAir Waste Systems, Tanks & Totes 15 09-29-2007 10:23 AM
Sprung door... one man's solution Safari Tim Doors & Locks 1 08-07-2004 06:41 PM
