Old 03-13-2011, 09:26 PM   #1
jeffkraft200's Avatar
1975 Argosy 28
Mobile , Alabama
Modifying a Fastec door lock
A little background, I purchased a 1975 Argosy 28' that needs alot of tlc. The PO must not have wanted to replace the door lock with a lock of proper vintage so he covered the door handle opening with a patch and tryed to install a deadbolt. I assume that did not work so well because he also installed a hasp style latch and a padlock. I can't say I would have put a vintage replacement lock in either with them goimg for a couple of hundred bucks. My solution to this was to install a Fastec RV lock. Fortunatley I am a machinist and have the tools to make what ever I need. First problem I encountered was the lock assembly had to be moved up about an inch and a half and rearward about half an inch so that the inside handle would be centered in the screen door opening. This now means a spacer will have to be machined to fit between the lock assembly and the inside of the door frame. Also the spring loaded catch in the lock and the deadbolt pin will have to be remade longer.
Name:	As purchased lock.jpg
jeffkraft200 is offline   Reply With Quote
Old 03-13-2011, 09:30 PM   #2
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Welcome to the forums Jeffkraft200,
Glad to have you with us. Nice that you can make the repairs to what the PO has done there. Would love to see pictures of the final product.
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 03-13-2011, 09:43 PM   #3
1975 Argosy 28
Mobile , Alabama
Day 1
What I did today was to remove the old patch and lock, removed the interior sheetmetal and insulation. With the new lock location figured out I cut a new patch for the outside. I had to remove the inner brace that ran with the midline, 1. to be able to rivet on the new exterior patch and 2. to remove about 3 inches of the brace for the lock. I made it as far as getting the new exterior patch and the brace riveted back onto the door. Tomorrow I will get the spacer cut and will start making the new deadbolt pin and door catch longer.
Name:	New exterior patch.jpg
Old 03-15-2011, 08:30 PM   #4
1975 Argosy 28
Mobile , Alabama
Day 2
Got the 1/2" spacer made to go between the door frame and the lock assembly. The pics show the gap I needed to fill, the spacer to fill the gap and reinforce the door frame, and the spacer inserted into place.
ID:	124616   Click image for larger version
Old 03-15-2011, 08:37 PM   #5
1975 Argosy 28
Mobile , Alabama
These are the lock parts I will remake to make up for the spacer I needed to put in. The last pic shows how all the parts fit in. Simple.
ID:	124619   Click image for larger version
Old 03-15-2011, 08:53 PM   #6
1975 Argosy 28
Mobile , Alabama
In case your wondering why the spacer? It is so that the inside part of the door lock is back far enough from the screen door frame that the deadbolt knob can still be accessed.
Old 03-15-2011, 09:06 PM   #7
moderator
Airslide's Avatar
Wilton , California
Images: 50
Thats a clean looking installation.
Thanks for sharing.
Vinnie
Old 03-17-2011, 06:11 AM   #8
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
jeffkraft200
You do nice, very nice work. Im glad I came across this post. Please keep posting as you complete your project. Im looking forward to seeing how it all finishes out. Thanks for sharing
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 03-19-2011, 09:22 PM   #9
1975 Argosy 28
Mobile , Alabama
Machined Parts Done
Got the new extended door catch and deadbolt pin made today. I made these pieces 3/4" longer than the originals. Tomorrow I will cut the new door frame opening and then figure out a way to close up and reinforce the old opening.
Old 03-20-2011, 11:12 AM   #10
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I too put a fastec latch in my door which has a cast frame. see post starting at #250
http://www.airforums.com/forums/f416...nte-26902.html
Old 03-21-2011, 04:57 PM   #11
1975 Argosy 28
Mobile , Alabama
Got the door frame cut and got the lock installed and all is working as expected. I still need to close up the old openings that the PO hacked into the door frames and I think I will go ahead and reskin the door now that I know the lock and location are good.
ID:	125064   Click image for larger version
Old 03-21-2011, 04:59 PM   #12
1975 Argosy 28
Mobile , Alabama
Have you had any issues with the latch since installing yours?
Old 03-26-2011, 03:02 PM   #13
Aerowood's Avatar
Arvada , Colorado
No issues at all, except I forget which direction to turn the key for the deadbolt. I need to mark that. I still need to modify the screen door to clear the lock. Just haven't got a round to it yet, just so much to do and so little time.
door lock, kt lock
