Old 12-17-2016, 12:53 PM   #1
1972 23' Safari
Sierra Vista , Arizona
Making new window latch shafts 1970s
My 1972 Safari needed a few new window latch shafts. I made them, it was relatively easy, but I do have some machinery that helps for this type of stuff-- an old lathe, and an old mill.
I used some long 5/16" bolts, first jammed an old nut on the end of the threads. Then cut off the head so it's the correct length. Turn the cut end to give it a chamfer, and turn the hex off the nut, and thin the nut a bit, so it fits into the latch housing. Then put it in the mill and cut flats on the threads, it needs to be cut 0.025" on each side (we made a jig for this, just a flat piece of steel in the vise to support the bolt while milling). Then drill the hole for the handle pivot pin, and install. Works well. And since they're steel instead of aluminum, they might survive a bit longer than 45 years this time.
jforb is offline   Reply With Quote
Old 12-17-2016, 04:54 PM   #2
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Looks great; a shop is like a pick-up truck - can't live without them.
sgschwend is offline   Reply With Quote
Old 12-17-2016, 05:20 PM   #3
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Nice work!
Dingo Girl is offline   Reply With Quote
Old 04-18-2017, 09:42 PM   #4
1976 25' Tradewind
Cottage Grove , Oregon
i like this
Toolmanbt is offline   Reply With Quote
Convert vintage door latch to modern double rotary latch & strike? Mixter Doors & Locks 5 02-19-2017 09:12 AM
rear window 1970s airstream Greg1410 Airstream Classifieds 0 04-19-2016 07:55 PM
1970s Hehr window weatherstripping Jammer Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 08-07-2012 02:17 PM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 09:52 AM
Window Latch Assembly (window locks) Sue&Von Windows & Screens 17 02-10-2009 06:32 PM
