Old 08-12-2017, 12:42 PM   #1
Montrose , Colorado
Lubrication for Windows / Aluminum
Hi all!
Have some windows (push open) that are a bit sticky, just wondering what everyone uses to lube up the aluminum on aluminum parts? I know WD40 is out as it collects dirt.
Just wondering if there is anything specific to Airstreams? Newbie question for sure, I appreciate the help!
1978 Argosy Twin 24'
Montrose, CO
Bartowski is offline   Reply With Quote
Old 08-12-2017, 01:01 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I use a silicone spray on all locks, rubber gadgets and pretty much any place else that is sticking. Silicone spray is also a key to trouble free ZipDee awning operation.
If you do not ready have them I recommend Rich's two Airstream maintenance books.
https://store.airstreamlife.com/coll.../books-and-cds
MICHAEL
Old 08-12-2017, 01:13 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
For lubricating metal parts that can't get oily or collect dirt, I use Finish Line Dry Teflon bike chain lube:
https://www.amazon.com/dp/B00U30TFAS...ing=UTF8&psc=1
Originally bought it for my bike (naturally), but now it sees a lot of use on my Airstream as well.
Cats and ultraleather Airstream upholstery don't mix!
Old 08-12-2017, 01:22 PM   #4
Montrose , Colorado
Thanks guys! Great suggestions!
Montrose, CO
Old 08-12-2017, 08:18 PM   #5
KK4YZ's Avatar
2017 23' Flying Cloud
Hiawassee , Georgia
One other thing...
Sticky windows are sometimes caused by the window sticking to the rubber gasket. Be careful or you can shatter the glass by pushing too hard on it.
If that's the problem, you need to take a credit card or thin piece of plastic & run it between the gasket and the glass to free it up. Then clean the gasket and treat it with a product called Protectant 303 or something like that.
The silicone lube is perfect for all the aluminum parts, like awning rails. No Airstream should be without it.
KK4YZ is offline   Reply With Quote
Old 08-13-2017, 12:09 PM   #6
2012 25' Flying Cloud
Naples , Florida
303 Lubricant that Rich Luhr mentions in The (nearly) complete guide to airstream maintenance. I too am a newbie, this is one of the first things i did, lube my gaskets. I see many using keys and credit cards to open windows, since lubing my gaskets ( i just like to say it), i have had zero issues! I am a believer!
ekm217 is offline   Reply With Quote
Old 08-13-2017, 01:08 PM   #7
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Inland Andy recommended silicone grease some years ago for seals. Won't work on everything, but better than aerosol in some instances.
Old 08-13-2017, 03:17 PM   #8
2019 25' International
Washington , Washington, D.C.
I think I remember one of Rich's Airstream maintenance books advising one to lay a strand of dental floss at bottom of windows - prevents rubber from sticking.
PatLee is offline   Reply With Quote
Old 08-13-2017, 03:30 PM   #9
BoscoMN's Avatar
2015 19' Flying Cloud
2017 25' Flying Cloud
Rosemount , Minnesota
I repurposed the tool that came in a Goo Be Gone sticker remover kit. We keep it in the kitchen drawer and use it whenever a window sticks (usually after we forget to wipe down the rubber with 303 Lubricant before the trip).
https://www.amazon.com/Goo-Gone-Stic...words=goo+gone
https://images-na.ssl-images-amazon....L._SL1200_.jpg
2018 F-250 6.2L Gas
Blue Ox SwayPro 1000#
BoscoMN is offline   Reply With Quote
Old 08-13-2017, 03:38 PM   #10
alhamilton's Avatar
1975 Argosy 26
1975 26' Argosy 26
Placerville , California
Does Rich's book cover my 75 Argosy 26'?
alhamilton is offline   Reply With Quote
Old 08-13-2017, 03:53 PM   #11
AWCHIEF's Avatar
Images: 33
They are nonspecific general manuals. I previously had a 1964 Bambi II and his first book was my bible. Using both of them has made my life much easier with 2006.
MICHAEL
Old 08-13-2017, 05:16 PM   #12
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I carry a plastic, disposable putty knife and use it to help open stuck windows. It hangs on one of the key hooks by the door.
2019 Ford Expedition Platinum
Old 08-13-2017, 11:38 PM   #13
2015 23' FB Flying Cloud
Redmond , Washington
Hi all!
I use silicone as others have suggested. It works very well, and in my experience it is best used regularly to saturate the seals.
I also installed the window poppers recently discussed on the AS Forum. They are inexpensive (about $20 for four) and easy to install (5 minutes each). These are terrific! But I still keep the seals lubricated with silicone.
http://www.airforums.com/forums/f454...et-132014.html
Good luck and safe travels!
D2
"Having differences makes a difference"
WestieHouse is offline   Reply With Quote
Old 08-14-2017, 01:25 AM   #14
Opinionated newb...
wave man's Avatar
2018 25' Flying Cloud
League City , TX
I can vouch for the books, extremely good information for someone new to RVs let alone Airstreams, just read mine through cover to cover to start the info percolating
Men are but men, and the greatest men are they who soonest learn the simpler things. ROBERT E. HOWARD
What a man does for pay is of little significance. What he is, as a sensitive instrument responsive to the world's beauty, is everything! H. P. Lovecraft
wave man is offline   Reply With Quote
Hitch Lubrication? AndyPenny Hitches, Couplers & Balls 13 11-21-2007 02:59 AM
Stabilizer lubrication? Fyrzowt Jacks, Stabilizers, Lifting and Leveling 14 09-16-2006 05:08 PM
Windows, windows, windows... Balquin Windows & Screens 4 07-04-2006 06:35 PM
Bal Stabilizer lubrication mandolindave Jacks, Stabilizers, Lifting and Leveling 4 02-19-2004 09:51 PM
Hitch ball lubrication Kistler Our Community 9 05-12-2003 12:48 PM
