Old 05-25-2012, 02:27 PM   #1
1968 20' Globetrotter
duxbury , Massachusetts
locked out of AS Help
I'm camping in my '68 GT AS and closed the door. The knob turns on its' axis and does not engage the bolt. Short of cutting the knob off, how can I open the door? Kevin
outandabout is offline   Reply With Quote
Old 05-25-2012, 02:37 PM   #2
Naper's Avatar
Loretto , Ontario
Take a look at the hinges. Can you drive the pin out.
Naper is offline   Reply With Quote
Old 05-25-2012, 02:48 PM   #3
dznf0g's Avatar
Oswego , Illinois
Call Andy at Inland. I don't have the number....google it....he seems to know how to get into all of them.
-Rich-
Old 05-25-2012, 02:49 PM   #4
dznf0g's Avatar
Oswego , Illinois
800-877-7311 is his phone number.
-Rich-
Old 05-25-2012, 03:23 PM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Try pushing in on the nob, hard, as you turn it. I had a similar problem in my 66 and that got the door open. Then fix/change the lock.
Old 05-25-2012, 03:37 PM   #6
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I have had some luck entering through one of the cargo hatches, depending on size and location. In my case I was able to push the bed out from the underside and get in. Of course I was smaller then also
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 05-25-2012, 04:27 PM   #7
goransons's Avatar
1963 22' Safari
Yakima Valley , Washington
Send a message via MSN to goransons
Be careful with that L-100 lock, discontinued and getting harder and harder to find. If you have some access doors and personally can't get in, find a good elementary kid that can use a screw driver, get him/her inside and have them remove the screws to take the inside handle off.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 06-04-2012, 09:18 PM   #8
Santa Fe , New Mexico
I am a new owner of a 71 Overlander and got no keys for baggabe compartments. Can the cylinders be changed?
Rich
rverruni is offline   Reply With Quote
