Old 05-16-2012, 03:15 PM   #1
1963 19' Globetrotter
Old Bridge , New Jersey
Little plastic piece:
Hello,
This is for a 1963 GT.
I had to replace a window today, and broke one of the little plastic pieces that attaches the hinge to the frame, it is a plastic piece that appears to snap together with a little spring in the middle. Doubt if these are still available so I need to find it from someone with parts.
Did a search and couldn't find the name of it.
njloco is offline   Reply With Quote
Old 05-16-2012, 03:22 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Got a picture?
Old 05-16-2012, 03:23 PM   #3
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
I don't know exactly what you are looking for from your description, but you could check with Vintage Trailer Supply to see if they have what you need: Vintage Trailer Supply - parts and supplies for vintage travel trailers and campers!
Good Luck!
TB & Greg and Abbey Schnauzer
#3954
Old 05-16-2012, 07:31 PM   #4
It's kind of hard to describe, when you crank out the window on a 63 GT,there are two arms that fold out and push the window out, it's where these arms connect to the frame of the window, inside a little track is a plastic piece that the arm connects to.
When you change the glass, you have to slide arms off of the window frame and these plastic pieces also slide out connected to the ends of the arms.
Hope this helps.
Old 05-16-2012, 08:11 PM   #5
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
It's called a nylon friction pad available here Nylon Friction Pad
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
