Old 05-24-2015, 05:47 AM   #1
1968 30' Sovereign
Kinglake , Victoria
left side door
I need to install a left side door in my 1968 Sovereign for Australian compliance. Can I buy a "normal' (right side door) door online and is it possible to have a door shipped to Australia?
Germanaussie
Germanaussie is offline   Reply With Quote
Old 05-24-2015, 07:36 AM   #2
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
I've looked for a 1968 replacement door since 2010 and have not found a good one.
To achieve your goal, you need a door and the door jamb. Without the corresponding cast jamb, a 1968 door only, does your concept no good. The jamb is built into the trailer frame/shell and will have to be removed and shipped as well.
You already have a door and jamb on the curb-side. There are hundreds of shade-tree, back-yard, driveway Airstream fabricators in the USA that would attempt the swap, and do a great job, even better than the Airstream factory. Cheaper and faster to import one of them to Australia for a few weeks, than finding and shipping a 1968 a door and jamb.
I've seen those Mad Max Movies and that tells me that there are already excellent metal fabricators in your Out-Back. There may also be an air-frame mechanic near you looking for side-work.
Isn't there a historical/vintage vehicle variance to the code?? or do you want to walk through from side to side??
PICTURES??
ALUMINUMINUM is offline   Reply With Quote
Old 05-24-2015, 07:57 AM   #3
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
I agree with ALUMINIUMINUM. There must be the ability to import and register vintage/antique vehicles to AU without having to modify them. I suggest checking into this more.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 05-24-2015, 08:19 AM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I would find an sheet metal shop that is well versed in vintage aircraft restoration and repair and have them move the door to the left side from the right side. That is, if it HAS to be done. I also agree, check and see if it is at all possible to get a variance for historical/vintage vehicles.
Aaron
WBCCI #XXXX AIR #2495
Old 05-25-2015, 04:11 PM   #5
1968 30' Sovereign
Kinglake , Victoria
Hmm, I posted a reply but can't see it, could have gone to the wrong place. I will look into the vintage registration again to maybe circumvent the whole second door topic. Thanks for your answers! If I need one, it is easier to get one made!?! That is good to know!
Germanaussie
Old 05-25-2015, 04:49 PM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have read that there is a very active Airstream community in Australia. If you can get hold of them you might be able to get current information on the laws.
MICHAEL
Old 05-25-2015, 08:21 PM   #7
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Why do you want two doors, it would be relatively easy to remove the door from the right side to the left
Aerowood is online now   Reply With Quote
Left turn and left brake lights not working Morgan guy Lights - Interior & Exterior 9 02-01-2015 07:08 AM
Switch to the left of entry door 1968 Sovereign oneofthemoms Electrical - Systems, Generators, Batteries & Solar 5 06-27-2013 05:18 PM
Door on Left Hand Side. Any models? cazna Windows, Doors, Locks & Vents 7 02-10-2012 09:09 AM
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
Right side, middle of the road, or left of center? DreamStream Off Topic Forum 19 03-02-2004 05:51 AM
