Old 07-02-2019, 03:11 PM   #1
2017 27' International
Box Elder , South Dakota
Key turns but deadbolt doesn't move.
I can't use my deadbolt it won't work. The key turns but the deadbolt doesn't move. I don't know if these pictures will help or not. I am stumped.
ID:	345212   Click image for larger version
ID:	345214   Click image for larger version
alphamale49 is offline   Reply With Quote
Old 07-02-2019, 03:26 PM   #2
Mollysdad's Avatar
When you turn the key with half the lock off, as in picture 1, does anything move?
Is it possible the deadbolt broke off and the lock part moves but the bolt doesn't reach? I can't tell from picture 4, but it sure looks recessed a lot.
Old 07-02-2019, 03:35 PM   #3
kpm
2018 25' International
Mound , Minnesota
Quite possible. An apparently common accident is trying to slam the door shut while the deadbolt is extended, resulting in a bent or broken shaft. We had Jackson Center straighten our bent deadbolt.
kpm is offline   Reply With Quote
Old 07-02-2019, 03:45 PM   #4
Mollysdad's Avatar
A bit of research and it appears that the lock is a TriMark 060-1300.
Here's a diagram if it helps! Let us know what you find.
Old 07-02-2019, 04:01 PM   #5
Mollysdad's Avatar
Looks like how this works.
I forgot to ask, If you use the inside thumb latch, does it work then?
Old 07-03-2019, 09:43 AM   #6
The deadbolt did not break off. Attached are more pictures. When 'assembled', if I am assembling it correctly, the key turns part way both ways but the deadbolt does not move. However, the deadbolt does move in or out when the cam arm is moved manually. Maybe when I assemble it I am not doing it correctly, but that offers no clue as to why it doesn't work because it should have worked correctly before I disassembled it. I am willing to order a complete new lock but I have no idea how I would replace to old one as it appears difficult to remove the internal assembly. I appreciate all the comments and welcome additional suggestions. Thank you.
ID:	345279   Click image for larger version
Old 07-03-2019, 09:45 AM   #7
No. Inside latch turns a little but does not move the deadbolt.
Old 07-03-2019, 11:25 AM   #8
2019 26' Flying Cloud
Summerfield , Florida
Had the same issue. Sliding Deadbolt has two surfaces. Surface next to the door skin is recessed back about 3/4 inch. I fixed mine by inserted a 1 inch piece of 1/8 inch hose back along the skin side. This keeps the recessed part of the bolt sliding forward to fully lock.
Pubtym is offline   Reply With Quote
Old 07-03-2019, 12:07 PM   #9
How did you remove the deadbolt? It seems the entire assembly would have to be removed to get at it. Do you have a picture? Thank you.
Old 07-03-2019, 12:26 PM   #10
Mollysdad's Avatar
Making progress!
I see you have the lock tumblers out. Good.
If I understand, the deadbolt does not hangup except when using the key.
According to the flyer I attached from TriMark, The lock cylinder is repairable.*
I'd take it to a locksmith and see if a tumbler is broken inside. May be cheaper than a new lock.
BTW, Out of Doors mart sells the entire assembly for $79. Just in case.
The good news is you're not locked in, and you still have another lock to secure the trailer.
I have the same deadbolt. Mine always seems loose, but if I tighten the screws it won't work. I suspect it's because Airstream uses a hollow door and I'm pinching the mechanism.
I'm learning with you!
BTW, If you replaced the lock, you'd only use the parts you have out now. I think removing the bolt would require taking some rivets out. Last resort.
Name:	Screen Shot 2019-07-03 at 2.28.07 PM.png
Old 07-03-2019, 05:19 PM   #11
Pubtym and Mollysdad. When the deadbolt is not all the way in but flush with the door, the key works to slide the deadbolt either out or in, which is what should be happening. It is not much of a difference but enough to prevent the key from unlocking the deadbolt if the deadbolt is slid all the way back. PIctures are posted. The picture on the left is the situation where the deadbolt can not be moved by turning the key. Then the bolt can be moved by pushing forward on the wire spring in the picture. The situation on the right is when the deadbolt works both ways. Pubtym posted that he prevented the deadbolt from moving too far with a piece of rubber hose. I am wondering how to do that. Thanks again.
ID:	345324   Click image for larger version
Old 07-06-2019, 03:16 PM   #12
dcasr's Avatar
1990 29' Excella
Stone Mountain , Georgia
_______________
You are fortunate to have access to both sides of the lock, even though a malfunctioning lock is a PITA.
We were on a Cajun Caravan when our lock broke with us on the outside. Locksmith couldn't fix it, and we were locked OUT. Got someone skinny to climb through the cargo hatch and unlock the rear emergency window. Lock still wouldn't open so for the next week two 74 yr olds were climbing in and out of the rear window constantly. Not a pretty picture. Southland RV fixed it when we got home. Hope you can find a new lock or a dealer to fix it for you.
+dcasr
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
dcasr is offline   Reply With Quote
Old 07-07-2019, 01:41 PM   #13
2016 19' Flying Cloud
Newtown , Connecticut
We've been unable to open our rear storage compartment. We had to remove the plywood bed board to get inside the compartment and removed the lock assembly to inspect. Still could not operate the lock. Short of getting a new lock assembly does anyone have suggestions on how this may be corrected? Thanks,
brundom is offline   Reply With Quote
Old 07-07-2019, 03:12 PM   #14
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
These deadbolts can be a little tricky. Since you have the inside exposed, lubricate everything that you see, all the moving parts. Extend the bolt and lubricate all sides. When you reassemble, tighten finger tight to start with. Then slowly tighten, testing the operation of the bolt as you go.
Different schools of thought on what best to use for lubricant.....either dry graphite or a good scilicone spray. I would try these steps before doing anything else
mayco is offline   Reply With Quote
City water connected but pump still turns on? trekerboy Plumbing - Systems & Fixtures 14 02-11-2018 04:54 PM
Compressor runs but needle doesn't move! ericjan2 Classic Motorhomes 6 10-23-2012 04:34 PM
Door key turns but doesn't lock MonaxLisa Doors & Locks 8 06-10-2010 02:51 AM
Key Turns and Turns..is this normal? help moormansmari Doors & Locks 10 11-25-2008 04:57 AM
